Alternator Questions
Why does everyone appear to want more amps?
Is the factory amps not sufficient?
How many amps is my truck drawing?
-(ah, key question I think,...if you have 10 subs and 100 amplifiers that can kill field mice, then sure, get two 3G alternators)
Thank you!
I do believe that the plug is called to be replaced anytime that its removed from the alternator. Who wants to do that everytime?
Minimal wiring changes and a junkyard donor and sounds like a possible replacement bolt (would need to replace it if it was ruined on removal either way) are easy to do, gets you a higher capacity charging system, and doesnt carry a fire risk without installing a new plug on the wiring everytime you take it off the alternator.
I hardly ever replaced the pigtail. If the connection felt tight and the wires looked ok I did not replace it.
No. It should be a 3G in a 1994. At least the ‘94 351W I bought out of an E-150 was a 3G and not a 2G. That is the only reason I converted to that alternator.
Yes…which is why a new pigtail was always included with a new or reman alternator.
Still doesnt mean its the right option, if a owner is comfortable or able to replace the pigtail, a wiring change to make it a 3g vehicle is admittedly more involved but its not much more.
I dont know if the 1g was a internally or externally regulated unit but If it was externally, then I only have experience with a 1g.
The externally regulated alts in the late 70s were cool, you could adjust the set point of the cars charging system with a screwdriver iirc, at the very least theres an adjustment procedure in the service manual.
If i had any say in the matter Id get some gm alternators made up to fit the mounting configuration of these engines. the 7.5 and 4.9 would have the easiest time fitting since its in the same plane as the shaft , but the crossbolting on the 5.0 and 5.8 would require special castings for sure for the front halves
The 4.9 I have is so close to workable except that the top and bottom ear arent level with eachother, and the one ear is threaded and the other is intended to encase the bolt all the way through to the other end of the bracket, making it require machining on a gm alternator with matching ear placements to make work and probably use a nut and bolt on the top ear.
I did, however, personally confirm that at least the pulley would be in the right spot assuming the ears on the gm alternator were in the right spot, iirc they matched the threaded hole ear, so someone could machine this if they were dedicated. Sadly the benefits are not good enough to warrant the effort and who wants to swap their case half everytime they need an alternator, which requires unsoldering the rectifier among other things to make it require downtime.
But the electronics are so much nicer and refined, much more simple, and the regulator uses a shelf-available pigtail and the whole thing would function with only one wire on the regulator simply to the charge indicator
Each one has built in soft-start ability like the taurus (and other small car engine) 3gs only
3g 140 amps to their benefit take up much less space because of how their case is shaped, i presume the stator diameters are similar enough to compare that
The ‘94 engine has a different serpentine belt setup than the ‘89. It also has a 3G alternator with three mounting bolts instead of the two bolt 2G. I bought a 3G wiring harness from a junkyard. Other than changing the green trigger wire connector because one was round while the other was square, it was plug and play.
And the true killer of some engines was peoples unwillingness or inability to have read that piece of paper lol
I checked my rig earlier and... it's a 2G 80amp alternator. I've been looking at the alternatives and will likely replace in the near future.
That said... are there preferred alts out there that folks swear by? I've been looking at the PurePower's 250 Amp Custom High Output. Anyone have an opinion on their alts or the company? Other alt suggestions?
https://www.tucsonalternator.com/pro...ernator/3-ORG/
Personally, I would not go over about 160 amps, and I would add a second power wire even with the 160
Why do you need a 250amp alternator? I am using a factory replacement 130A. Look up 2G to 3G conversion on garysgaragemahal.com for info on how to do the conversion. It shows what needs to be done to modify the bracket as well as which vehicles have the correct two bolt alternators and how to wire it up.
The original questions starting the thread were intended to better understand what's transpired with factory alts from that time period, to understand if they're dangerous and should be considered for replacement, and to understand what others have done to both mitigate the risk of a potentially dangerous situation while understanding what the benefits are of going with a larger amperage, 'modern' alt. If you're saying that one shouldn't upgrade to a 250amp, is there a reason why that is? Sorry, just trying to understand. For the layperson, the idea of more - and more consistent - power appears to be the correct route (especially given the limited investment increase)? Look forward to your insights/comments.
As I posted before, even a reman 2G unit can function flawlessly. An upgrade to 3G would be nice when this one gives out. (I was not given a new connector with the alternator)
If you had a large stereo, heated seats, and auxiliary halogen lamps, maybe I could see a larger unit wanted. I run a basicass 130A on my '88. Just has a small JL 300/2 amp (150x2rms) running the audio, plus the usual bits they had stock. Lights. Hvac. Etc. It keeps up fine.
I pointed out what needs to be done to swap it in previous posts. You were given links by others. It is all over old Stang mag articles too.
tertiarily, (is that even a word?)
theres a few ways to make that more power that might not be ideal:
Its going to involve stuffing more guts into the alternator that converts the AC To DC, which is where the heat that kills components that are trapped inside the case is largely affecting. The stator windings as long as they havent failed , are pretty durable and dont exactly have much to worry about
The electronics hate heat, and output lowers with heat, and heat lowers their lifespan. Another way they get higher ratings is to drop the alternators pulley size so they spin faster and thus are producing more at low RPM, there is a limit of how fast the shaft can spin, and idk what it is but it is important that your crank-to-alt pulley ratio doesnt enable it to get to that speed
Id imagine output will taper off after a certain speed but im not sure what that is. No idea how much is to be gained by this alone, but its devils in the detail. A better charge wire as mentioned would be needed. ID use a dedicated ground on a 3g alternator regardless if you get 250 or 130amp
because theres a threaded hole in the back un-used on them and these trucks have terrible engine grounds. and old.
The 130amp i think will do you well, and not having a special alternator is not only cheaper it means you wont need to do the alt twice if you need to replace or warranty. youd likely be in the auto store or rockauto to get a temporary unit when/if the 250 dies.
A rear camper being used , if you have a need for 12volt source power, id recommend getting a battery that is maintained by your alternator but its decoupled from the trucks loads If your trailer connector is 7 way and you have the relays underhood, you have a wire dedicated to this already
But it can be added fairly easy with junkyard or ebay parts or using a relay and doing your own run
