Tfi module differences
Old Apr 23, 2025 | 09:56 PM
preppypyro's Avatar
preppypyro
Hey guys and gals, I have a 94 f150 with a 302 ij it that I am trying to diagnose some poor running conditions and a code. The previous owner changed a bunch of things and I believe I am down to checking the TFI module or the pcm.
I have a few parts trucks kicking around. One is a 300 6 cylinder, two are 351s of about the same year 93-95) and one is an 87 with a 302 in it.
I have done some searching and haven't found a definite answer. Are these interchangeable at all, or at least enough I could swap one to see if that is an issue?
Old Apr 23, 2025 | 10:08 PM
Soup bean's Avatar
Soup bean
https://www.ford-trucks.com/forums/1...k-93-96-a.html
Old Apr 24, 2025 | 03:47 AM
AuroraGirl's Avatar
AuroraGirl
94 should, without any basis other than what i think, be a black CCD. is that a motorcraft replacement? Do you get codes?
Because a cheap black one if youre having issues woudl help determine
BUT the color isnt consistent on all. For example, delphi makes a black and grey one but they are both in grey cases
Old Apr 24, 2025 | 06:16 AM
manicmechanic007's Avatar
manicmechanic007
Back in 86-87 there was only 1 module (DY 425 Motorcraft)
Only the ones that have an "ignition diagnostic monitor" programmed into their processors need the black module
The 4.9 6 pop did not have that diagnostic monitor IIRR, maybe in 1995 and 1996
Simply swap modules and see if a code 212 pops up, that'll tell you if you have the monitor or not, and whether you need the black DY1077 ignition module or not
Old Apr 24, 2025 | 06:52 AM
Scndsin's Avatar
Scndsin
From the above link. Says it all for your 94/5.0
Originally Posted by rla2005
Yes, your 1995 model year Bronco should have a black ICM. Your truck has the Computer Controlled Dwell ignition which requires the appropriate Ignition Control Module. Ford/Motorcraft CCD style ICMs are black in color.
1993 and earlier trucks use the gray colored Push-Start style Ignition Control Module. There are two different versions.
One is distributor mounted
Motorcraft - DY1074 (supercedes DY425)
Ford - 5U2J-12A297-AA, 5U2Z-12A297-A
Wells - F121
Niehoff - FF409
BWD - CBE24
Standard - LX218
NapaEchlin - TP31
Delphi - DS10051
Transpo - FM425
MSD - 83648 (Made by Transpo above)
The other is a remote mount Push-Start ICM
Motorcraft - DY1075 (supercedes DY533)
Ford - 5U2Z12A297B (supercedes EZ-12A297-A)
Wells - F125
Niehoff - FF411
BWD - CBE33
Standard - LX226
NapaEchlin - TP33
Delphi - DS10053
Transpo - FM533
1994 and later trucks use a remote mount CCD-style ICM
Motorcraft - DY1077 (supercedes DY679, DY667, DY645)
Ford - 5U2Z-12A297-D (supercedes F1PZ-12A297-A)
Wells - F139
Niehoff - FF413
BWD - CBE40
Standard - LX-241
NapaEchlin - TP29
Delphi - DS10056
Transpo - FM544
This is discussed at length on this forum pretty much every week. Ford's documentation for the most part have the part numbers/descriptions reversed for the actual application. The aftermarket copied their info so most have the same issue. The above is correct and has been verified dozens of times.
Old Apr 26, 2025 | 11:03 AM
preppypyro's Avatar
preppypyro
Thank you for all of the replies.
I am getting a code 212, i did buy the truck used from someone else who swapped a whole ton of things on the truck to try and fix the issue. I did start reading about the tfi modules, but I find they get pretty confusing when it comes to swapping, and I read a lot of conflicting info about the black vs grey in certain years, etc.
I will likely try to swap one or two out and see what happens. Thank you for all of the help! I'm guessing I will be making another post in the future regarding this pesky 212 code though haha.
eagle243
2009 - 2014 F150
Apr 8, 2024 10:27 AM
YooperUno
1983 - 2012 Ranger & B-Series
Nov 10, 2022 12:58 PM
forkliftjoe
Feb 13, 2017 04:22 AM
jd_jd_
Engine Swaps
Mar 10, 2006 02:54 AM
homedepothauler
Nov 12, 2002 09:21 AM
