Build help
Old Apr 22, 2025 | 01:54 PM
Myoung419's Avatar
Myoung419
3rd Gear
Build help
Hello everyone, I am currently in the process of rebuilding a pair of 390FE's and wanted to get opinions from others on the build and maybe some info I didn't have. I have two motors that I'm building one is 0.060 Overbore and the other is STD. I found and purchased a third for super cheap to take the internals (under $100 bucks). The interesting part is that this third motor was a 390PI block including a C4AE-B Crankshaft and a mechanical cam with solid lifters (No pushrods sadly). I also found a practically brand new TRW 1-TM572 camshaft in a parts lot which is noted to be a non-cobra jet replacement cam for the 428 (mild cam).
I also have 4 cranks - 360 2T that came with the STD motor / 390 2U I got free in a parts lot / 390PI C4AE-B crank from purchased third motor / and a 428 1UB that I bought a while back.
I planned on using the 428 crank with the 0.060 motor and the 390PI crank with the STD. my main question is should I make a 410PI using the mechanical cam/lifters with the 428 crank or should I just go with a regular 410 using the TRW camshaft and use the other one to basically remake a fresh 390PI motor. I don't really know if there would be a crazy boost in performance I was just pretty interested to see what that motor would sound like and what power it could possibly put out.
Any help/suggestions would be nice. Thanks everyone!!
Old Apr 22, 2025 | 07:06 PM
85e150's Avatar
85e150
JMO.
No solid lifters. Sell the cams to someone
Go with a roller cam and pick out what you want.
Flat tappet cams and lifters are unreliable these days due to materials and oils not being what they should be.
Old Apr 23, 2025 | 06:10 PM
Myoung419's Avatar
Myoung419
3rd Gear
I see, Sadly where I'm at now I cannot really turn back unless I want to wait a while for things to sell and new parts to come in. I recently got the pushrods needed for the mechanical as I already had a pair of hydraulic. At this point the 0.060 motor is ready to be bolted on and turned, just trying to figure out which road of the two that I have in front of me that I should go down.
Fellenz
Dec 11, 2014 10:58 PM
bigern26
23
Sep 29, 2010 04:01 PM
71fordkid
Dec 28, 2009 04:09 AM
RapidRuss
25
May 2, 2004 06:42 AM
