Recently acquired a 2001 Lincoln navigator as a donor car and need some help with the ECU.
Not sure if this is the right form for this, if its not could you point me in the direction of a forum that could help.
Problem:
I want to be able to tune the stock ECU if possible. I also am going to use a manual transmission so I need the engine to run with out the auto trans harness. I would like to know if either of these are possible or if I should just go to a speeduino or rusefi.
