1978 - 1996 Big Bronco
Pwr Steering swap?
Old Mar 12, 2003 | 05:34 PM
33bronco's Avatar
33bronco
Pwr Steering swap?
Where can i find a saginaw pump for a 5.0 engine for my 92 bronco. the stock pump what a P.O.S. i totally fried it after putting 33" tires on now it barely works, sometimes it doesn't. Has anyone ever tried turning 33" tires which have bad camber with out pwr steering it sucks. Then there is the squeek don't even get me started.
Old Mar 12, 2003 | 06:50 PM
Lookinfurfun's Avatar
Lookinfurfun
Pwr Steering swap?
E150 van. I know at least a '93 will work, but I'm sure you will find one in the same era vans. Check out Keith's Superford site for some pics.
Old Mar 12, 2003 | 06:57 PM
greystreak92's Avatar
greystreak92
Pwr Steering swap?
You will also need the bracketry for the Saginaw pump from the van as well. The Saginaw pump will not fit the bracket for the Ford OE pump. Possibly an adaptor for the high pressure hose too. Not 100% certain on the adaptor. Someone knows though.
Old Mar 12, 2003 | 11:05 PM
tite4x4's Avatar
tite4x4
Pwr Steering swap?
Try checking out AGR Steering. http://www.agrperformance.com/agr/index
I have used there replacement pump on my '90 fullsize Bronco running 33"x12.5" tires. Their direct replacement pump made a big difference and it was very quite in comparison to the stock peice of !@#!@!. Going from an iron fist grip to a one finger steering with out breaking a sweat. didn't need to go to a saginaw pump. But if you do yould definatly need to change the bracketry.
Hope this helps
Old Mar 16, 2003 | 04:47 PM
33bronco's Avatar
33bronco
Pwr Steering swap?
I swapped it out today what a difference. When i stop at a stop sign i keep thinking my truck stalled it is so quiet.
thanks
Old Mar 17, 2003 | 12:06 PM
Lookinfurfun
Pwr Steering swap?
Which pump did you put in?
Old Mar 17, 2003 | 06:55 PM
33bronco's Avatar
33bronco
Pwr Steering swap?
I installed the Saginaw i picked up at the yard for 25 bucks with a pulley and bracket and output hose. WHAT A GOOD DEAL!!. By the way I did not need a an adapter the only thing i had to buy was a foot of 3/8" hp hose and to clamps for the return.
MIKE138
Mar 2, 2016 01:51 PM
momutt
Engine Swaps
Dec 19, 2015 01:38 PM
mechmanf18
1997 - 2003 F150
Dec 8, 2015 06:27 PM
awfulaggravated
Jun 21, 2007 01:36 PM
rjs4ds
Jun 8, 2004 07:04 AM
