Was notified on the info screen tonight that another update is ready for install. Details were related to window bounce back and single click rollup. Updates the driver and passenger window modules. Was at a car wash so just letting it push to the overnight recurring schedule. Saw some may have had bounce back issues in other threads, so hopefully this helps ya. Will post more info tomorrow after install.
I've got a '24. Seem to get the updates fairly quickly when they come out. Could be due to being connected to Wifi when parked at the house, but that's just a wild guess.
Update details:
Window Performance
This update reduces instances of window bounce-back and improves the one-touch up feature.
Driver Door Module, Passenger Door Module
DDM-25.20.4.3
Not sure if my truck got that update ... thought I'd share this ..... from time to time, not often, my drivers window using the auto-up switch function, would "auto bounce back". I would then just roll it up using the "partial" switch function. It seemed to reset on it own. Well. last fall as I was entering a car wash - some of you know the routine, put left front tire in the conveyor track, put the truck in neutral, foot off the brake ..... Well as the truck started into the wash tunnel, my window was down, as the attendant was giving me the "how to" instructions. I hit the auto up function AND - YEP "auto bounce back", window went half way down. I hit the auto up function again, just as the pre rinse began wetting the truck, AND - YEP, window "auto bounced" again. By then the the pre rinse spray was coming in the front window - this time I used the partial function to roll the window all the way up. - I laugh about it now LOL Well, later, I reset the drivers window and deleted the auto up function, but the kept "auto down" function. I don't miss the auto up function on the drievrs window at all.
Mine tells me there's an update. Has for a few weeks now. Tried to download it both by using the update now button and the auto update overnight, but it never does it.
Same issue except the car wash episode. Every month or two, the drivers window just decides to bounce back. Does it enough to aggravate me, then quits and works normal. Have to look for that update and hopefully that will resolve the issue.
Mine was downloaded and installed last night. The only impact from the update was the loss of my oil temperature in the detailed view. I’ll have to hunt around and see it I can re enable it. Thanks, Ford.
Any luck in figuring out how to get the oil temp display back up? Care to share how if so?
Drew 6 nines, (HA!)
Thanks for the intel. Got it back.
Honestly I've never noticed that. LOL. Way back in the day (the 90's) when I was trying to setup a Hotmail account, I tried Drew, but it was taken, then tried Drew9, then Drew99, etc. The first one that wasn't already taken is still my current username.
