IWE solenoid
Old Apr 18, 2025 | 06:59 PM
DavidVan1974's Avatar
DavidVan1974
1st Gear
IWE solenoid
I have a 2020 Ford F150, I have IWE solenoid not send out the pressure. I already replaced 2 different solenoids and still not working. I know this is common problem.
Old Apr 18, 2025 | 09:12 PM
JKBrad's Avatar
JKBrad
I recommend eliminating the IWEs.
Old Apr 19, 2025 | 07:09 AM
SpencerPJ's Avatar
SpencerPJ
I'm not great at troubleshooting iwe. That said, what do you mean not send out pressure? Have you replaced the check valve? It is the most common failure. YG-360.
edit: what is it doing or symptoms that make you think iwe issue?
Old Apr 19, 2025 | 09:31 AM
KJ Smith's Avatar
KJ Smith
It operates in a vacuum. There will not be any pressure.
Old Apr 19, 2025 | 01:39 PM
JKBrad's Avatar
JKBrad
It's likely one of the IWEs is broken, and the constant vacuum leak is ruining the solenoid. That's what happened on my truck. The leak at the IWE damaged the solenoid and the vacuum pump. I got tired of constantly messing with the system, and hearing noises from my hubs, so the IWEs were eliminated.
Old Apr 20, 2025 | 03:49 AM
MrOrange645's Avatar
MrOrange645
4wd Low
Yup. To echo what JkBrad said, even Ford recommends the IWE delete now. I had no issues with mine, but deleted them preemptively. I pulled and plugged the vacuum line on mine, so it can be reversed, but it does not affect the truck or function of the 4WD or Automatic 4WD at all.
Old Apr 20, 2025 | 09:54 AM
JKBrad's Avatar
JKBrad
You can just unplug the solenoid. But follow Ford’s TSB to prevent further vacuum
leaks. If the is still noise at the hub, like my truck had, the one of the IWEs is likely broken.
TSB, as you can see For no longer recommends trying to fix the vacuum issues to the hubs.
https://static.nhtsa.gov/odi/tsbs/20...81917-0001.pdf
Old May 12, 2025 | 08:10 AM
adgjqetuo's Avatar
adgjqetuo
Why does the TSB only apply to those with 4A? I thought all 4x4 trucks had IWEs in them?
Old May 12, 2025 | 01:49 PM
JKBrad's Avatar
JKBrad
Who knows. Trying to limit their payout, I would guess. Like some many TSBs and recalls that list build dates, even though many people outside those build dates have the same issues. And TSBs don't get performed unless there is a diagnosis, or some other compelling reason to do it. They are not mandatory.
Old May 12, 2025 | 03:25 PM
seventyseven250's Avatar
seventyseven250
There's some difference in the system for trucks with 4A vs those without. Both have an IWE system.
Old May 13, 2025 | 09:35 AM
KJ Smith's Avatar
KJ Smith
4A can be run full time on dry pavement.
klausd
Nov 4, 2021 06:07 AM
sccamper
Nov 19, 2017 12:11 PM
Bonanza35
Sep 15, 2014 09:55 PM
Kavu
Apr 7, 2013 01:24 AM
Rosson03
Jan 30, 2012 02:36 PM
