5.8l no spark
Old Apr 18, 2025 | 06:12 PM
F150 89's Avatar
F150 89
5.8l no spark
What’s up guys so I have a 1989 ford f150 5.8l truck was running good then out of no where died a few times out of no where found out the alternator was dead and draining my battery causing the truck to shut off due to draining power I replaced the alternator and everything was good truck was running good then became hard to start again and the key stoped working it wouldt engage the starter I would turn it and nothing would happen if I jumped the solinoid it would turn over but not start so I though it was ignition switch replaced that and now truck turns over but still no spark I also hooked up a test light to negative battery terminal and probed the two wires on ignition coil plug and left one I get 12v the right side green wire I get nothing the light wants to light up but is very faint and don’t show a reading are both wires supposed to be hot when the key is in the on position
STUFF REPLACED SO FAR
oem motor craft ignition switch from parts giant
complete new distributor I did reuse my old distributor sensor that sits on the side tho witch is the original most likely from 1989
also had a second ignition coil sitting around unknown if it’s good but I tried that one also and got the same no spark results
Old Apr 18, 2025 | 09:34 PM
88n94's Avatar
88n94
I assume the sensor on the side of the distributor you are talking about is the ignition module? I would remove it and take it to a parts store that can test it. Very common for them to go dead.
When you reinstall the ignition module be sure to apply heat sink grease to the back of it.
Old Apr 18, 2025 | 10:46 PM
F150 89's Avatar
F150 89
5.8l no spark
yes sorry drew a blank the ignition module and ok will do I also have a brand new one that came with the distributor but it was an off brand and figured the oem one would be better but I’ll try swapping it and see if anything changes and yes I do have the thermopaste thank you for your help . But any way to test these ignition coils to see if they are good before I buy a new one just to rule it out
Old Apr 18, 2025 | 11:49 PM
88n94's Avatar
88n94
I don't know how to test a coil. Most any parts store can test them pretty easily I believe. Coils do go dead but not very often. Much more common for an ignition module to go dead.
Old Apr 20, 2025 | 07:17 PM
F150 89's Avatar
F150 89
No spark
Thanks buddy u where right turned out to be the ignition module swapped a new one in fires right up
Tcunningham
17
Mar 9, 2020 08:21 AM
Fistfull of dollars
16
Dec 26, 2017 11:57 PM
purplegoat
1978 - 1996 Big Bronco
Aug 10, 2008 04:04 PM
tastyklair
23
Dec 15, 2005 07:59 PM
manlikesford
Apr 23, 2005 07:39 PM
