Rear Sway Bar
Old Apr 18, 2025 | 05:29 PM
Dan1954's Avatar
Dan1954
Rear Sway Bar
My 2025 F350 was delivered to the dealer this week & I am having the dealer add a few things before I pick it up. I have a rear sway bar on my 2017 F350 & I want to have the new one set up the same way. My salesperson got back to me today & said I have to go aftermarket because Ford doesn’t have one. That seems funny to me because I remember discussions about them on this forum. Also I bought one for my 2017 which was installed by the dealer before I picked it up. I told the salesman I think he is wrong but who knows, maybe Ford doesn’t provide them anymore. Anyone know for sure? Thanks
Old Apr 18, 2025 | 05:32 PM
PSDlongbox's Avatar
PSDlongbox
SRW F350 with Camper Package gets a rear sway bar from factory.
Old Apr 18, 2025 | 06:06 PM
powerboatr's Avatar
powerboatr
yup dealer can order that one...it's pricey
E trailer has a few options just under 700
Which is still high
Been looking for one as well
Old Apr 18, 2025 | 09:55 PM
Alloutdrs1's Avatar
Alloutdrs1
I had this saved from the Tremor forum, this is for the OEM rear bar. Looks like your around $330 for the OE bar sourcing parts.
Old Apr 19, 2025 | 04:55 AM
shailey's Avatar
shailey
I added a Hellwig Bigwig sway bar to my 24 F350. It was about $700 as Robert Sloan stated above. I’m really happy with it and I would certainly buy in again. But it was expensive……
Old Apr 19, 2025 | 05:58 AM
Bugzilla46310's Avatar
Bugzilla46310
Wouldn’t air bags give you similar results with more capabilities?
Old Apr 19, 2025 | 06:20 AM
Dan1954's Avatar
Dan1954
Good question & I don’t know the answer. I’ve been thru much of the US, about 15-20,000 miles towing a 38 ft 5th wheel & am happy with the performance of my current truck with the sway bar. I also have Timbrens on the back.
Old Apr 19, 2025 | 08:13 AM
powerboatr's Avatar
powerboatr
not sure..
Sway bars do not provide or add weight or carry capacity
They work by reducing body roll
and some sway .
yes stiffer spring rates do control roll to an extent..by nature of being stiff or bags aired up more.
but the stabilizer bar is more effective at roll
And does not require stiffer springs
Old Apr 19, 2025 | 09:32 AM
Charlie98's Avatar
Charlie98
Even my SRW F250 XL 2WD... with the camper package... has the rear sway bar. It's rather spindly... if you want some steering rigidity, I would probably go aftermarket...
Old Apr 19, 2025 | 07:14 PM
Scoobertdoo's Avatar
Scoobertdoo
That is AWESOME, thank you. Hated that the Lariat ult removed the camper packed with the sway bar.
I realize the helwig would be much beefier but 700 is a little more then I wanted to spend for a test
Old Apr 19, 2025 | 08:26 PM
MyOthersa5-ton's Avatar
MyOthersa5-ton
I believe, in reviewing the parts list on fordparts.com, quantity 4 bolts W500634S309 is actually W500634S439 for the '23+. The "S309" comes back for Transits, Fiestas and Explorers
Old Apr 20, 2025 | 04:59 PM
RadRick's Avatar
RadRick
Before ordering my 2024 F-350 I was researching rear sway bars and came across this link as well: https://www.ford-trucks.com/forums/1...-long-bed.html This is for a 2022 but has some good information. I wasn’t able to find it right now, but someone posted a link showing there are four sizes of sway bars, one for SRW gas, one for SRW Diesel, one for DRW gas, and another for DRW Diesel. Then there was a much larger one for F-450 pickups.
Old Apr 20, 2025 | 09:31 PM
Alloutdrs1's Avatar
Alloutdrs1
Some good info in that thread, I will be sourcing the parts to add the OEM bar to my truck. I will have to research it further because even in that thread there are some discrepancies with some of the Fastner hardware like @MyOthersa5-ton brought up.
dwstucke
35
Oct 7, 2023 03:33 PM
DecodanMcQ
May 29, 2021 02:52 PM
Neal 97 250
13
Dec 7, 2008 09:47 AM
aadamson
Jun 7, 2006 12:24 AM
narcicus
Jul 18, 2003 02:50 PM
