Seriously, the only clue you gave is "won't start". There's a page worth of "ideas" out here, easily. Provide some details and improve your odds. Good luck.
You may have fuel in the tank, but are you sure it is full pressure at the rail?
Have you checked if the fuel filter is clogged up?
Are you sure you are getting spark from the coil packs?
If they aren't getting power to them none of them will have spark.
Sounds dumb, but make sure you have a clear intake path.
Critters like to build nests that can block the air flow.
Aside from that, BareBonesXL pointed out there isn't much info you gave us to go on.
no coil packs just one old fashioned coil and i do get spark i cant believe the 5 year old fuel pumps would go bad??? the originals went 25 years? gonna try a starting fuild can today. i need it back on the road.
