DPF filter cleaning
Old Apr 18, 2025 | 10:41 AM
Ashkicker's Avatar
Ashkicker
2nd Gear
DPF filter cleaning
Is it possible to use a Kiln to remove the soot and ash for the DPF filter? Or would I have to replace it.
2015 Ford F-550 6.7 Powerstroke
Old Apr 18, 2025 | 10:50 AM
helifixer's Avatar
helifixer
you would have to cut it open and take the filter out, bake it blow it out and then put it back together.
there are a few companies that offer that service. I don't remember the company names though. someone will be along with that info though.
where you live would also be helpful.
Old Apr 18, 2025 | 11:30 AM
Overkill2's Avatar
Overkill2
Pittsburgh Power is on the east coast... I know there's some on the west coast and some in between.
https://pittsburghpower.com/pages/dp...natives-shogun
Old Apr 18, 2025 | 11:40 AM
Ashkicker's Avatar
Ashkicker
2nd Gear
I'm over in New Mexico
Old Apr 18, 2025 | 12:13 PM
helifixer's Avatar
helifixer
Jim @HRTKD I believe it was told me about a place around Denver.
Old Apr 18, 2025 | 01:58 PM
kayakingpoodle's Avatar
kayakingpoodle
I found a local company (San Antonio) that was reasonable cost and fantastic customer service. Highly recommend calling around your local area.
Old Apr 18, 2025 | 03:08 PM
Overkill2's Avatar
Overkill2
Check out the link I posted as they state the different stages and how they clean the particulate filter... pretty interesting.
Old Apr 18, 2025 | 05:03 PM
speakerfritz's Avatar
speakerfritz
Look for a new or low miles take off …with all the weight loss going on…should be cheaper than bake cleaning…and..if you are lucky..find one with all the sensors becuase your sensors are not going to come out…factor sensor madness into the cost of bake cleaning
or you can go water methonal injection. The kits on my last two trucks cost 500 bucks and they clean dpfs very well
Old Apr 18, 2025 | 05:25 PM
Overkill2's Avatar
Overkill2
Old Apr 18, 2025 | 05:26 PM
helifixer's Avatar
helifixer
F550 trucks have a unique exhaust so nothing else will work.
Most F550 trucks are commercial or hot shot trucks so most have intact emissions, no take offs laying around,
Old Apr 18, 2025 | 06:04 PM
speakerfritz
yes…if chasis cab the dpf section is first then the scr section
if pick ….the scr section is first then the dpf
Old Apr 18, 2025 | 06:43 PM
helifixer's Avatar
helifixer
f550 is only cab and chassis
FishOnOne
6.7L Power Stroke Diesel
20
Mar 14, 2025 08:10 AM
whporwil
6.4L Power Stroke Diesel
Aug 12, 2010 06:46 AM
