Hard starting
Old Apr 17, 2025 | 09:05 PM
SDF450's Avatar
SDF450
5th Gear
Hard starting
If my 2017 F450 has sat for a few days it takes several attempts to start.
The remote start fails.
From inside, glow plug indicator comes on the once it goes off & start button is pressed. Engine does a very short crank & glow plug indicator comes back on for a few seconds then goes off. Press start, partial crank again. Repeat process 3-6 times then motor will turn over & start.
Any ideas of what could be causing this issue?
Old Apr 17, 2025 | 10:56 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
One or both batteries bad, get them load tested.
For proper load test, at least one battery needs to be disconnected, or you'll get a false reading.
Old Apr 17, 2025 | 11:13 PM
SDF450's Avatar
SDF450
5th Gear
Replaced batteries and had new batteries load tested when this happened with the new batteries
Also replaced the fuel filters
Old Apr 17, 2025 | 11:33 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Well, if you are sure they were properly tested, then the next thing to look for would be faulty ground connections.
These trucks are EXTREMELY sensitive to electrical faults.
Old Apr 17, 2025 | 11:39 PM
SDF450's Avatar
SDF450
5th Gear
Test seemed right, but truck ran 30 minutes to get there.
Old Apr 18, 2025 | 08:36 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Did they disconnect at least one of the batteries before testing?
Old Apr 18, 2025 | 09:26 AM
SDF450's Avatar
SDF450
5th Gear
Yes, they disconnected one battery, tested the other. Connected other battery & disconnected the tested battery then tested the other.
Old Apr 18, 2025 | 10:12 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I'd be tracing all the ground connections then.
Doesn't have the check engine light on does it?
Old Apr 18, 2025 | 12:46 PM
SDF450's Avatar
SDF450
5th Gear
The check engine light isn't on.
Sure would be nice if they didn't bury everything.
Jake_A
Feb 25, 2022 08:46 AM
07 F250 Aggie Mobile
Oct 5, 2018 09:35 AM
Vice1391
Dec 19, 2016 01:32 AM
n.o.yat
Oct 22, 2008 08:11 PM
RexinReading
22
Sep 30, 2008 09:44 PM
