Sponsored by: Real Truck
Transfer case codes
Old Apr 19, 2025 | 10:20 PM
ifrythings's Avatar
ifrythings
The test I’m asking you to perform is only on the solenoid, the other tests they ask you to do is for other problems which I don’t think you have.
Your first picture shows testing the solenoid but is drawn wrong, the middle pin should be where your one probe goes (doesn’t matter which one) and then you test the left side and then the right side. Do that and report what you get for results. You can also apply 12v to the middle pin and ground each side pin and you should hear a click from the solenoid if that side works (one click from each side terminal).
Old Apr 22, 2025 | 08:34 PM
Mykah knabe's Avatar
Mykah knabe
ok, i put one probe on the middle and then tested the left and the right sides. Left resistance was 43.1 ohms and right was 52.3 ohms.
‘99Powersmoke
Jun 15, 2022 06:19 PM
jstihl
Oct 2, 2020 03:26 PM
RobertVT
Jan 27, 2017 10:26 AM
89LX306
Dec 14, 2011 01:56 PM
Hiflyer746
Oct 30, 2007 08:05 PM
