Will this cab fit?
Old Dec 4, 2003 | 11:41 PM
skoebl's Avatar
skoebl
Will this cab fit?
I found a cab from what I think is a 77 f-100 in a barn at my friend's house. My question is, will it fit (without much effort) on my 77 f-150?
Oh, and if it isn't from an f-100...How well would late 70's model cabs fit as well?
Thanks in advance.
Old Dec 4, 2003 | 11:49 PM
BigBully's Avatar
BigBully
Should be The same. F150 to F100 Is just in the suspension not the Body. As far as I know the Cabs from 73 to 79 are all the same.
Old Dec 4, 2003 | 11:57 PM
frameoff's Avatar
frameoff
The cab should fit no matter what year it is from between 73' 77. (I have no experience with 78-79) Where you run into swapping problems is in the beds 2 wheel vs 4wheel. At least the 2 times I swapped cabs I had no problem and I swapped once from a 2wheel drive cab to a 4wheel drive frame with no probs. The other was 4x to 4x
Old Dec 5, 2003 | 08:16 AM
Tim350's Avatar
Tim350
What kind of trouble do you run into with swaping the bed from 2 wheel to 4 wheel?
Old Dec 5, 2003 | 10:01 AM
774x4's Avatar
774x4
That's what I was wondering too. I just did it on Sunday and didn't run into any problems.....
Old Dec 5, 2003 | 12:06 PM
ecarter50's Avatar
ecarter50
77-earlier 3/4 ton 4x4 have 34" frame. 77 1/2-later 3/4 ton 4x4, most 2wd have 38" frame.
Old Dec 7, 2003 | 11:43 AM
skoebl's Avatar
skoebl
New information......
The cab is from a 1970 F-100....Same question applys.
