what upgrades can prevent this
Old Apr 13, 2025 | 09:53 AM
speakerfritz's Avatar
speakerfritz
any weld on of bolt on braces for the frame ?
Old Apr 13, 2025 | 10:08 AM
kayakingpoodle's Avatar
kayakingpoodle
Common sense is about all that will prevent that. The camper was way to heavy for the truck, the frame failed do to fatigue from being way overloaded. There is plenty of analysis of this incident to read out there on the internet.
tldr; never trust a salesman.
Old Apr 13, 2025 | 10:29 AM
westracing01's Avatar
westracing01
Not so much the camper alone, but the trailer on a 4' extension just put a hell of a lot of leverage on the truck.
Combined they were way too much stress.
Old Apr 13, 2025 | 10:50 AM
Euroman's Avatar
Euroman
It’s a dually, surprised me that it collapsed like that.
Old Apr 13, 2025 | 11:35 AM
Overkill2's Avatar
Overkill2
I know nothing about towing like that but thinking out loud, isn't the frame open in that location where it broke? If one wanted to reinforce the frame, wouldn't boxing the frame and fabbing up additional cross members strengthen it work?
All that said, taking into consideration what you guys said about having too big a bed camper plus towing the additional load makes sense about why that happened.
Old Apr 13, 2025 | 11:37 AM
Old and soft's Avatar
Old and soft
My boy has one of those. Those are heavy. 2 slides, genny, huge water tanks, even has a dry bath. 1 ton truck is not enough.
Old Apr 13, 2025 | 11:38 AM
speakerfritz
Looks like the fail was just forward of the forward leaf spring mounts….which is the weirdest part of the whole frame.
so could a weight distribution hitch have moved the stress more forward on the frame away from the area immoderately in front of the forward leaf spring bolts.
I’m curious since I plan a slide in and will probably want to tow a small toy hauler
i have an f-450 with helwig over leafs ( both leafs installed), summo springs (2500lb rears) , silastic shackles (hd version)
Plan on traction bars as wrll
Old Apr 13, 2025 | 11:44 AM
kayakingpoodle
Welding on modern frames is not a good idea, it is cheaper in the long run to buy the right truck for the task. The pictures of the failure in the op were throughly investigated the sales people for both the truck and camper misrepresented capability and ratings, and the customer did no research to verify it was a compatible combo. The owner also put many more miles on the combo than most others that used the same combo.
Flex metal far, often, and long enough it will break.
Old Apr 13, 2025 | 11:47 AM
Overkill2's Avatar
Overkill2
That looks like my gen truck and even if a F450, still had the open part of the frame.
Didn't Ford upgrade and make the Super Duty frames stronger for the new Alumina Duty trucks?
Old Apr 13, 2025 | 11:49 AM
Overkill2's Avatar
Overkill2
Looks like you know a little about that... was that a 350 or 450? And obviously either one would not have mattered as they have the same frame.
Old Apr 13, 2025 | 01:46 PM
speakerfritz
just did a quick and dirty lookup for my year truck....there are no charts to show slide in camps and tow behind combinations. no warnings about not doing it either.
https://tailoredtrucks.com/wp-conten...wing-guide.pdf
Old Apr 13, 2025 | 03:44 PM
kayakingpoodle
It's there, max payload, max tounge weight, GCVW.......
Like most things in life, just because you get away with it 1 time or a 100 times doesn't mean you'll get away with it forever. Many examples of this in engineering, it is why there are safety factors and the reason they scale with life safety concerns.
Old Apr 13, 2025 | 06:54 PM
Overkill2's Avatar
Overkill2
I remember seeing this video... you Alumina Duty guys have what appears to be a fully boxed frame which the 11 to 16s did not. And it looked like that pre 17 dually broke where it's not boxed...
Now not saying that this means you can do what the guy in the pic did, but it appears those new trucks have a pretty strong, redesigned frame under them.
Old Apr 13, 2025 | 07:14 PM
kayakingpoodle
https://youtu.be/mvkz5XY4oTY?si=zBkJzOcghwsZHmN4
True, mine is an '18 with a service body, so I have less to worry about, but the pictures in the OP are a stark reminder of the value of due diligence and salesmen rarely look out for your best interests.
Old Apr 13, 2025 | 07:23 PM
Overkill2's Avatar
Overkill2
That is true... that did look like one BA enclosed trailer that dude was pulling with god knows what inside.
That looks like a 450 from what appears to be the commercial wheels the 450s come with... the 19.5s IIRC.
