What axle do I have?
Old Apr 11, 2025 | 12:33 PM
tominboise's Avatar
tominboise
I have a new to me 2022 F250 lariat CCSB 4X4 with the 7.3l gas engine and 3.55 locking rear axle. Also has the 9900lb GVW package. I am wanting to service the axles. The owners manual mentions a 10.5, 10.8 and 11.8 axle, which all have different specs for the fluid weight. I will tow about 5500lbs with this truck. Also, is the factory gasket on the front and rear axles reusable?
I appreciate the help.
Old Apr 11, 2025 | 12:42 PM
B-ManFX4's Avatar
B-ManFX4
I believe the 7.3L dictates you will have the M275 axle.
Old Apr 11, 2025 | 01:20 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
My 2022 F250 PSD has the 10.5 sterling axle under it.
How many bolts on the cover?
Sterling has 12.
Old Apr 11, 2025 | 02:53 PM
tominboise's Avatar
tominboise
Sterling has 12.
It has 12 bolts, so it must be the Sterling. Do you know if the factory gasket is reusable on this axle? How about the front axle gasket?
Old Apr 11, 2025 | 04:10 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I believe they come with RTV and no gasket from the factory.
I am about to do the gear lube change on mine, and I bought a reusable gasket, it is a Victor Reinz 71-20065-00.
No idea on the front, my truck doesn't have one.
Old Apr 11, 2025 | 05:01 PM
jcb804's Avatar
jcb804
3.55 ratio for gas trucks is the Sterling 10.5. RTV is the factory gasket for both front and rear, youll have to buy aftermarket gaskets if you dont want to use RTV.
Old Apr 11, 2025 | 06:46 PM
longhaultransport's Avatar
longhaultransport
Or, suck it out and refill from the fill hole.
Old Apr 11, 2025 | 07:24 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I doubt you could get the syphon tube all the way down to the bottom of the housing to get all the fluid out.
Fill plug is on the front side, near where the pinion goes through.
Plus, no way to clean any metal trash out that may be in there.
When I do mine, I am going to replace the cover with one that has a magnetic drain plug.
Old Apr 11, 2025 | 07:36 PM
JayCarver's Avatar
JayCarver
That will be a sterling 10.5
Not a reusable gasket. If your planning on keeping the truck long enough that you will be the the next guy to service the diff then I would highly recommend you pick up a “Lube Locker” gasket, they make life easy.
Old Apr 11, 2025 | 08:27 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
The Victor reusable gasket I mentioned above is heavier than the lube-locker and cheaper.
Old Apr 11, 2025 | 08:35 PM
tominboise's Avatar
tominboise
I just ordered a gasket.
Old Apr 13, 2025 | 09:18 AM
JayCarver's Avatar
JayCarver
Never heard of them, sounds like a better option!
Old Apr 13, 2025 | 11:58 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
My new aluminum diff cover was waiting for me when I got home this evening, looks way cool, and has a nice size drain plug.
Will make a thread about it and the install later.
Old Apr 14, 2025 | 08:10 AM
drj564's Avatar
drj564
If you have the M275 you have a drain plug and don’t need to remove the cover. Just the lowest bolt.
Old Apr 14, 2025 | 08:30 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
We're talking about the 10.5 Sterling axle, not the M275, no drain.
