Sponsored by: Real Truck
2011+ Brake Caliper Options
Old Apr 11, 2025 | 12:10 PM
stever1000's Avatar
stever1000
I noticed my drivers front caliper has a cracked dust boot when I was pressing the piston in to change pads. I haven't noticed any sticking yet, but I assume as water and dirt gets inside it will seize up from corrosion.
I've read lots of other threads with issues with reman calipers and have been looking at options for new versus reman... would new raybestos calipers be better than reman raybestos/centric/ACDelco, etc since they are new pistons and bores and not rebuilt? They are a bit more costly, but I don't mind paying upfront to do it once, rather than change them out in a year or two, I hate anything related to disconnecting the brake lines and bleeding the brakes.
I like the added bonus of new calipers so I can have a spare set (no core to return) to try rebuilding myself if I change them before the piston corrodes.
Old Apr 11, 2025 | 03:27 PM
ifrythings's Avatar
ifrythings
I’ve had way better luck rebuilding the calipers myself vers buy reman crap. I get the seal kits and new pistons (usually $50 does one axle) and spend a while cleaning the seal and dust boot bores before assembling. So far since 2017 I rebuilt the front calipers and bought rears as the axle I got was missing them, got 3 years out of the reman ones and they started sticking, rebuilt those in 2020 and haven’t had any caliper issues since.
Old Apr 12, 2025 | 09:58 AM
Overkill2's Avatar
Overkill2
I had my brakes done at my buddy's shop... he lets me buy my own parts. I went with new Raybestos calipers from Rock Auto, no cores required.. One of the mechanics told me the last brake change that the rear calipers were looking a little corroded inside where the piston seals are. Since I was doing the rears, I said screw it and did the front calipers as well... now just have to be better with inspecting those slide pins more to keep them lubed and sliding freely.
2011 FORD F-350 SUPER DUTY 6.7L V8 DIESEL Turbocharged Caliper | RockAuto
Old Apr 12, 2025 | 12:03 PM
paclikj's Avatar
paclikj
I have a 2013 F-350 6.7 crew cab. I pull a 35' toy hauler.
I replaced front and rear brakes.
3/14/2021 59,600 miles
Bought from Summit Racing
Everything and I am 100% happy with them.
Powerstop #PWR-K6405-36 Brake Kit (Pads and Rotors)
Raybestos - Calipers
Old Apr 12, 2025 | 05:54 PM
Overkill2's Avatar
Overkill2
I use the coated Powerstop rotors with the Z17 pads I believe... I like them as I just daily drive my pig. The calipers were coated as well for the WNY winters.
Back in the day, I ordered plenty for my 96 F250 through Summit Racing... loved ordering through them as well. Plus they were close to me in Buffalo.
To be honest, have never price checked with Summit against Rock Auto. I'll have to do that next time when I order more parts...
Old Apr 25, 2025 | 05:58 PM
stever1000's Avatar
stever1000
Thanks for the replies. I am leaning toward the Raybestos new just for piece of mind
Old Apr 26, 2025 | 01:05 PM
Overkill2's Avatar
Overkill2
I never stated, but I believe the calipers I ordered were the new Raybestos coated calipers.
Old May 1, 2025 | 11:16 PM
droldsmorland's Avatar
droldsmorland
I too fight the WNY craptastic winters. The slider pins need to be inspected 2X/year. Or at tire rotation or winter/summer tire swap.
I'm ready for new caliper cages (brackets). Sick of re-greasing these schiztty pins. Thought about drilling/tapping zerks into them. Just an all around crappy design.
Prob should bite the bullet and do high quality calipers/brackets.
When I do it will use Power stops all the way and coated everything. I use the Geo plated rotors on my daily Heep (Jeep). They last the longest in the new tax york salt.
Keeping the brake fluid flushed every 2-3 years has allowed the OEM calipers last 90K miles and still goin. To date just one set of rotors & pads from the Ford parts counter.
Important to replace those soft hoses. They are a wear/safety item. Replaced all 4 last year.
Old May 1, 2025 | 11:43 PM
mterickson's Avatar
mterickson
I've used Raybestos parts for several decades. Don't recall any major issues. When I managed a parts store, that was the brand I recommended most for brake parts due to minimal warranty returns we had with them.
Old May 2, 2025 | 06:11 AM
WE3ZS's Avatar
WE3ZS
There are 5 soft hoses, you missed one.
Old May 2, 2025 | 03:27 PM
Overkill2's Avatar
Overkill2
Yeah I use Powerstop coated rotors and Z17 ceramic pads. Just daily drive her...
I have my buddy's shop do the brakes... my knees are shot...
I took apart the new calipers I bought, took out the pins and a few already had little rust on them... made in Chicom. Cleaned them up and put my own stuff on them before my buddy's shop installed the new brakes.
I use Planet Safe Lubricants AiM lube. Rubbed a light layer on the pins. Then coated the pins with their grease they have. I also used the AiM lube on my factory locking hub dials to keep them free and turning. The older hub got tougher to turn in winter but it still moved. Will pull them this upcoming time off, have them sit in the sun and let the lube drip down through the body and dial interface (where they meet).
Going to check the pins at one point this year but yes, I was lax in doing this. This is a requirement here in a rust belt area.
Old May 8, 2025 | 11:05 AM
stever1000's Avatar
stever1000
Does anyone have experience with Dynamic Friction? They sound good and I wonder how they compare to Raybestos? The Raybestos new calipers on Rockauto just have a plain finish, no coating.
bglitning
Feb 9, 2024 01:11 PM
svtdoug2
Sep 22, 2021 12:39 PM
BlackTruckDave
Oct 19, 2016 12:23 PM
Green Giant
May 21, 2009 06:50 PM
burley68
1983 - 2012 Ranger & B-Series
Jun 1, 2008 12:50 AM
