traction bars - sources
Old Apr 11, 2025 | 10:30 AM
speakerfritz's Avatar
speakerfritz
had traction bars on my prior truck and its time for bars on my current turck.
the last set was from one up off road.....their website seems to be down.
other options?
Old Apr 11, 2025 | 11:28 AM
cpobst's Avatar
cpobst
Got mine from PMF.
Old Apr 11, 2025 | 12:16 PM
CCradier's Avatar
CCradier
other options?
One up Offroad is now S&B.
https://sbfilters.com/collections/suspension
Edit: I am also running One Up Off Road bars. Love em'.
Old Apr 12, 2025 | 07:05 PM
speakerfritz
I looked at the install instructions for DRW kit Torxz Traction Bar Kit Install F250/F350 & F450 Installation Manual
looks like its a short traction bar mounting to the frame immediately before the forward leaf spring bolt.....is this the kit you have? should be fine for my DRW.
Old Apr 12, 2025 | 07:08 PM
speakerfritz
Originally Posted by cpobst
Got mine from PMF.
their kit would work but they are not answering emails.....I have to make sure they dont send me an SRW kit. ubolts for DRW are larger....also need to know about how they mount to our blow mold box frame.
install instructions so I can review would be nice.
so far, I got install instructions for s&b and stryker .
Ill call PMF monday before I decide.
thanks
Old Apr 12, 2025 | 08:47 PM
speakerfritz
saw the video for the s&b install. the video shows removing the lower leaf on the leaf stacj and the install pdf does not......not too crzy about removing the lower leaf stack and that would be a show stopper for the s&B traction bar choice.
will call them to see if that step is really necesary.
Old Apr 12, 2025 | 10:27 PM
CCradier's Avatar
CCradier
Yes,that is where mine mount to. you do not have to remove the lower leaf. You can however flip it over to get a little better flex out of the spring pack itself. On a truck like yours I dont think I would sweat that. I did not get the kit with lift blocks. Mine replace the lower mount itself.. I am running the PMF deaver springs and shackles now, NO block. I will get some pics tomorrow and post them up.
Old Apr 13, 2025 | 08:33 AM
speakerfritz
I interesting
i was going to rotate my tires this weekend but I’ll hold off on that…removing 480lbs of rear wheels when doing the track bar would make things easier.
Old Apr 13, 2025 | 08:34 AM
CCradier's Avatar
CCradier
Old Apr 13, 2025 | 08:35 AM
CCradier's Avatar
CCradier
Also I can say with a supercharged 7.3 they absolutely work!
Old Apr 13, 2025 | 09:55 AM
speakerfritz
thanks for the picks
im going to call them monday
Old Apr 13, 2025 | 04:35 PM
speakerfritz
David from S&B sent me a link for the same style bars I had on my previous truck.
https://sbfilters.com/products/short...-traction-bars
Old Apr 14, 2025 | 05:58 AM
Superdave71's Avatar
Superdave71
Fritz, did you have to drill holes in the frame for those?
Old Apr 14, 2025 | 09:34 AM
speakerfritz
the long bars need 8 holes per side.
For the long bars they give you bolt pairs that are strapped together ….you have to fish them thru the frame using the nearest 1” hole.
Or you can weld them in if you want
Old Apr 14, 2025 | 02:49 PM
WK15's Avatar
WK15
Ok, I'm to assume these are for pavement princess correct or haulers?
Let me see if I understand what the traction bar does. It holds the rear axle from moving front to rear. Only in a neutral / centered position. Now for right to left movement there is none. Example coming off an uneven surface with a foot of drop whether gradual or sharp drop off. Now, with a normal rear suspension the rear axle will move up and down ( flex ) with the contour of the ground. If you are putting this traction bar in place and it does not move. What stresses are you putting on the axle welded or bolted on to the axle? I'm not seeing where the system articulates. Maybe I'm not understanding the system.
I watched this video from Wehrli Custom Fabrication Inc. Their traction bar ( WC Fab ) seems to articulate front and rear while, the above systems from S&B and One Up Off Road do not. Do we want articulation?
What is the preferred bar length 60 / 68 inches?
https://www.wcfab.com/i-31644652-201...tegory:1394330
