engine idle problem
Old Apr 10, 2025 | 09:24 PM
Aus f150's Avatar
Aus f150
Trailering
engine idle problem
Hi all, my 90 F150 5.0 AOD. is now increasing the idle when selecting a gear from park or neutral and at the lights the idle sometimes drops down to 500 rpms and then it will hunt. If i touch the acc pedal a little the engine goes back to a nice smooth idle.
No codes are comming up for this problem and i replaced the tps and that made a huge difference to the engine. Have not removed the computer yet for checking leaking capacitators. The truck runs really nice apart from this problem.
Thanks in advance. Getting electrical parts for this truck in Australia is not easy , i use Rock Auto.
Old Apr 10, 2025 | 09:55 PM
Truckwardo's Avatar
Truckwardo
Maybe fire the major tune up at it. Plugs, coil, filters, EGR valve, PCV, Idle air control, ground straps and battery cables, order a 12 pack of oil filters and some wiper blades to make shipping worthwhile. Do a smoke test first to check for air leaks.( The idle air motors used to fail alot back in the day. )And they get slow and sloppy. The EGR valves don't work great and need replacing after a few decades. A smoke machine is around 120 AUS$ and great to have.
Old Apr 10, 2025 | 10:19 PM
Aus f150's Avatar
Aus f150
Trailering
Thanks but i have already given the engine a full tune, replaced all the egr components, No vac leaks , i use Cummins oil filters and will get a new iac valve.
Old Apr 10, 2025 | 10:22 PM
Truckwardo's Avatar
Truckwardo
Ok the only weird ghost it can sometimes be is the flat ground straps. They look good. Buy they're causing excessive resistance on a circuit and can sometimes cause electrical gremlins. Particularly with aluminum intakes. But I'm 90% thinking IAC
Old Apr 10, 2025 | 10:53 PM
Aus f150's Avatar
Aus f150
Trailering
Did all the ground straps with heavy duty cable. My iac is clean inside but i am going to replace it .
Thanks.
Old Apr 10, 2025 | 10:58 PM
Truckwardo's Avatar
Truckwardo
Thanks.
nice. You're doing all the right things. Rebuilding the ECU isn't too bad. Just a few capacitors and sometimes resistors.
Old Apr 11, 2025 | 06:15 AM
JJF20's Avatar
JJF20
Thanks.
Can you give the details to “full tune”. Takes the guess work out of it.
Also note replacing parts with new aftermarket parts today, is not a guarantee they work better, or at all. If you’re not having an issue with something specific, I’d be hesitant to replace it. Especially multiple things at once - makes trouble shooting more difficult if there is an issue.
Old Apr 11, 2025 | 07:33 AM
torq'ta 5 8's Avatar
torq'ta 5 8
try these before buying
Vincent_Diesel
Oct 11, 2023 08:41 PM
kyle1979ford
Feb 3, 2022 05:57 PM
spliceman02
Aug 16, 2008 11:27 AM
sbauld
Oct 15, 2003 07:48 PM
