///// broke a bit while doing lower ball joint /////
Old Apr 9, 2025 | 12:15 PM
Andyinchville1's Avatar
Andyinchville1
Hi
Mechanic broke off a small piece underneath the nut getting off the old ball joint
Is this a problem? He said it's not but then again that's probably what he would say being that he broke it LOL
Thanks
Pics
Broke area
Broke area
Old Apr 9, 2025 | 02:12 PM
wwhite's Avatar
wwhite
Its only a problem if you need camber/caster adjustment.
But, since those are so old and rusty, you'd be replacing them anyways.
Cannot blame the mechanic for old and rusty parts breaking.
Old Apr 9, 2025 | 02:34 PM
JJF20's Avatar
JJF20
In theory they could migrate slowly, or slightly. The slot is broken off. It has two slots, opposing each other, one will fit over the tab on the axle beam. That said I highly doubt it’ll ever move, and I would run it. Has it been aligned yet?
Those are non adjustable eccentrics. If you need to replace, try a set of Moog adjustable eccentrics if you need to adjust. Otherwise, you’ll have to find that particular eccentric to get it back in alignment, they are pre set.
Johndg1991
Dec 22, 2022 01:21 PM
DustMan24
Mar 10, 2019 03:10 PM
Adam Serino
Nov 4, 2017 05:12 PM
bullnose1985
21
May 21, 2017 08:20 PM
Violjohn78
Mar 30, 2004 10:34 PM
