Timing Cover Gasket
Old Apr 9, 2025 | 09:15 AM
noles05's Avatar
noles05
5th Gear
Timing Cover Gasket
Hello everyone. I am rebuilding an 89 F250 with a 460. I have a fel-pro gasket set kit. The issue is the timing cover gasket has an extra hole on each side second hole up from the bottom legs. Not sure what they are for. I called Fel-Pro and they didn't either. Has anyone else come across this during their rebuild. Not sure if I should get another gasket from a different manufacturer (they don't have the extra holes) or use what I've got.
Old Apr 9, 2025 | 09:20 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Which one do you have?
or
or
Old Apr 9, 2025 | 11:34 AM
noles05's Avatar
noles05
5th Gear
The fel-pro. They are both the same except for the extra holes
Old Apr 9, 2025 | 12:18 PM
My4Fordtrucks
How can they be the same but different? If you don’t think it will seal where the extra holes are then try a different brand.
Old Apr 9, 2025 | 12:26 PM
noles05's Avatar
noles05
5th Gear
I'll explain it so you can understand, the gaskets are the same except for the extra holes. That means all the bolts holes line up with the exception on the two extra holes. Stop being an ***!
Old Apr 9, 2025 | 12:47 PM
My4Fordtrucks
I was not being an a$$. If there are “extra” holes that are not in the old gasket then the gaskets are not the same. I also said…
Good luck with the repair.
noles05
Apr 10, 2025 02:07 PM
granny_rocket
Oct 23, 2013 10:47 PM
mike2112
Feb 19, 2009 11:08 AM
FoMoCo390
Dec 31, 2004 08:23 AM
