Timing Cover Gasket Question
Old Dec 30, 2004 | 06:37 PM
FoMoCo390's Avatar
FoMoCo390
I went to put on my timing cover today and noticed that the felpro engine gasket kit comes with what seems to be two different gaskets. One it a thin blue paper gasket and the other is a thicker black foam looking gasket. Both line up with the bolt hole pattern on the timing cover. Which one do I use, and what is the other one for?
dan
Old Dec 30, 2004 | 09:39 PM
thunderguns71's Avatar
thunderguns71
I havent saw the black one you describe, but I always get the thin blue one and use it, havent had a problem yet.
Old Dec 31, 2004 | 12:51 AM
gtex's Avatar
gtex
Ive used the fel-Pro R.A.C.E. setup for FEs a a couple times. I only noticed the one timing cover gasket. That being the blue paper type. Maybe, they have upgraded the kit to include a "Performance" version of the timing cover gasket. Either should work fine. I've had no issues with the blu paper gasket.
then again, mine is leaking now, but I think it's the intake or valve covers. I've just given up, and decided that FE motors have an active external lubrication system....deal with it :-)
Old Dec 31, 2004 | 01:58 AM
Hypoid's Avatar
Hypoid
Gee, all these years I couldn't decide if it was auxillary cooling, or rust proofing.
Thanks Gregg!
Old Dec 31, 2004 | 08:23 AM
lee's Avatar
lee
Gtex,
AMEN!
Lee
