1949 flathead engine rattle
Old Apr 9, 2025 | 06:08 AM
BorzoiBob's Avatar
BorzoiBob
1st Gear
Hi Looking for help. 1949 Mercury station wagon flathead engine rattle . Noise is rev related in all gears when holding a constant speed , not there accelerating or on the overrun ! A throaty, roary, rattle . Old worn engine . Any help appreciated .
Old Apr 9, 2025 | 08:22 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
This is for Ford Trucks up through 1947.
The trucks with the related flathead engine would be over here: https://www.ford-trucks.com/forums/forum41/
That all said, I would start getting real facts:
*A compression test on all cylinders
*A Vacuum test
Old Apr 9, 2025 | 11:12 AM
Rust Wrangler's Avatar
Rust Wrangler
Might start by removing the front drive belt and verifying it isn't something driven off of it that's causing the noise. Good luck!
Old Apr 12, 2025 | 12:25 AM
52 Merc's Avatar
52 Merc
I'd check for an exhaust leak. They can be more obnoxious and rattly sounding than an internal knock would be. Rods and mains are more metallic and deep inside sounding. Valve train noises are closer described as a tick, typically. A cracked exhaust manifold, blown gasket or a leaky pipe is more external and raspy. You might try looking under the hood at night, in the dark, with the engine running. It's easier to see the flames that way.
tex_ag
2009 - 2014 F150
16
Jan 26, 2023 12:25 PM
96pos
Dec 9, 2022 09:41 AM
Amer Sbeitan
Jan 6, 2017 10:14 AM
the gruffalo
Mar 8, 2015 10:41 AM
