Engine Sudden Misfire Situation
Old Jul 23, 2025 | 09:58 PM
Rusty Bucket Ohio's Avatar
Rusty Bucket Ohio
Originally Posted by wwhite
I'd be tempted to re-torque you passenger side before removal, that will tell you something.
Great Idea … I will do that and report 👍
Old Jul 23, 2025 | 10:01 PM
Rusty Bucket Ohio
Originally Posted by wwhite;[url=tel:21621162
21621162[/url]]Did you use new head bolts or reuse the old ones?
I re-used the old bolts
Old Jul 25, 2025 | 11:01 PM
Rusty Bucket Ohio
Ok … so I ran a straight edge on the head and couldn’t see any gaps … I had a feeler gauge (.010) smallest i had, and couldn’t find a gap either …
so I pulled the passenger side head but I did not do a torque test as my torque wrench is at my storage 10 miles away … but same situation as the driver side that the short head bolts were almost loose and the longer bolts had good torque. I didn’t get a picture of the gasket as it was getting dark but the head gasket had signs of loosing good contact. This head did not pass my feeler gauge test as I was able to slip the .010 under my straight edge in several places. I’ll check the block tomorrow but I’m assuming that I should have the head’s shaved flat … new bolts recommended ? also ?
Old Jul 26, 2025 | 01:15 PM
DaveMcLain's Avatar
DaveMcLain
Reusing the old bolts should not be a problem. When they are tightened they are supposedly tightened to about 80% of their yield strength. This means that while they do stretch when tightened they are not permanently elongated and theoretically they could be torqued over and over until the threads wore out without yielding. To me it sounds like the head gasket compressed more than it should have during heat cycling, enough that it made a noticeable difference in the clamping load when you took it apart. Then it blew out between the cylinders.
In my personal experience I've had excellent results from Engine Tech gaskets, all of their stuff really. But they do offer a regular and a heavy duty gasket for some applications including the 302.
Dave1972
All Things Towing
86
Apr 2, 2024 11:12 AM
bad_idea
Sep 6, 2018 03:32 AM
Raymgriff
17
Mar 26, 2017 06:26 PM
phinner
Jul 10, 2013 12:17 PM
jsutton
General Automotive Discussion
May 30, 2007 05:12 PM
