X-pipe or H-pipe?
Old Dec 4, 2003 | 09:32 PM
LIL_WAGN_98's Avatar
LIL_WAGN_98
Question X-pipe or H-pipe and Glass packs or turbo mufflers?
What is the performence differences between the X and H pipes and which one would you recommend on a 3.0 V6? Also what would you recommend for sounds at different RPM's glass packs or turbo mufflers?
Old Dec 6, 2003 | 02:00 PM
kevinrf250's Avatar
kevinrf250
on a V6 go with the turbo muffer I had one on my ranger and it sounded good, alot better than the glasspack that was on it. You only need to worry about an H-pipe or X-pipe if you are doing true dual exhaust.
Old Dec 7, 2003 | 10:01 AM
nd4spd's Avatar
nd4spd
ive got tru duals and not x or h pipe...the guy who did it said that i didnt need it...something b/c of backpressure i think .....help me out on this plz.... got a 5.0 f-150
Old Dec 7, 2003 | 01:04 PM
kevinrf250's Avatar
kevinrf250
if you have true duals and h-pipe or x-pipe will help a little. If your truck is fuel injected when the crossover is placed before the oxygen sensor it will help get a better reading for the sensor. They help balance the pressure between both sides, and are suposed to help on low end power. I have always had an H-pipe on my truck since the duals so I don't know how much it will help though.
Old Dec 9, 2003 | 01:15 AM
Coogles's Avatar
Coogles
X pipe will give you the best performance, it will also quiet down your exaust 7-9 decibles. Instead of ballancing the gasses like an H pipe, it intersects forcing them to colide giving a scavenging effect. H-pipe only helps if u have uneven gas flow.
Old Dec 9, 2003 | 09:17 AM
nd4spd's Avatar
nd4spd
will it sound better with an X- or H- pipe? mine is fuel injected i dont know if i could put in a x pipe b/c the exhaust pipes are sooo close together...jus an idea
Old Dec 10, 2003 | 01:04 AM
kevinrf250's Avatar
kevinrf250
Couldn't help on the sound difference between the two, but you don't need very much room to run either.
Old Dec 12, 2003 | 02:23 PM
ranchero77's Avatar
ranchero77
if you search you will find this has come up before. I have seen and heard plenty of info on it and there is only a small gain in power 5-10hp.
it mainly helps balance the system. say you have flowmasters and it just doesent have that mustang sound. put in the H or X pipe to get the sound right. all the other reasons are going to depend on the specific vehicle apllications as for engine size, sensors locations, or pipe size.
Old Dec 12, 2003 | 03:07 PM
DanTana's Avatar
DanTana
I just put a pipe where my muffler was on a 5.8. Since I had cats on it I figured that was enough muffler. It isn't that loud at all and has a nice throaty sound.
Old Dec 13, 2003 | 12:01 AM
Coogles's Avatar
Coogles
mine is cut off behind my cat right now on a fuel injected 5.8. Ya it sounds pretty nice, in fact it might sound REALLY good if my engine hadnt blown its gaskets and covered the plugs in oil.
Old Dec 13, 2003 | 11:01 PM
f100guy's Avatar
f100guy
go to mustangexhaust.com and listen to all the different x and h pipes as well as different mufflers and headers. it is a good site to check
Old Dec 14, 2003 | 11:04 AM
StrangeRanger's Avatar
StrangeRanger
A 60° V-6 doesn't have the unbalanced exhaust pulses of a V-8 so it really doesn't need either. On the 5.0 mustangtests i've seen, the x makes a little more peak HP, the H a little more mid-range torque; no huge difference either way.
Old Dec 14, 2003 | 11:39 AM
rebel_ford4x4's Avatar
rebel_ford4x4
i dont mean to get off topic, but i had to ask.
are you happy with no muffler on your truck?, im assuming its the 351 since you say 5.8. i have a 351w and im thinking about cutting my muffler off and leaving just the cat and im also looking for the crackly aggressive sound, but not overly loud.
Old Dec 14, 2003 | 11:44 AM
f100guy's Avatar
f100guy
it sounds crappy i did not have a 5.8 but i had 2 cats in one pipe and no muffler. it was a 5.0. just get a 18 inch or a 24 inch glasspack and it will sever you well. not too loud but a good rapping sound. but it would be better if you at least cut one cat off though
Old Dec 14, 2003 | 11:47 AM
rebel_ford4x4
i only have one cat to begin with.
my other option was to go with an 18"glasspack into a Y pipe with dual outlets, but if i can go with no muffler and have it sound the way i want for free then ill do it.
