New fuel sending unit problems
Old Apr 3, 2025 | 07:28 PM
Rumbling302's Avatar
Rumbling302
I have a 1980 f100, fuel sending unit was always reading empty. I put a new one in( look identical) and is reading full with about 5 gallons of fuel in it. Pretty sure it’s not stuck cause it read empty when the tank was empty. Needing some help figuring out this problem. Also when tank is full gauge reads over the F mark and I haven’t started truck just turned key if maybe I need to run it to get an accurate reading. Anything will help thank you. This is the sending unit I bought https://www.jegs.com/i/JEGS/555/78796/10002/-1?gad_source=1&gbraid=0AAAAAD6OBRHjkDKyxEc0Vws6jdI gDMhfw&gclid=CjwKCAjw47i_BhBTEiwAaJfPpvd1NDeFZuR-l7vUJ0BRbk57OazoDMSbd-QzZPOUui6lnu1OTZMw9xoC7mAQAvD_BwE
Old Apr 4, 2025 | 06:45 AM
Franklin2's Avatar
Franklin2
You will have to take it back out, hook it up temporarily, and swing the unit by your hand and watch the gauge. It may need to be tweaked, the arm can be bent to make it read closer. More than likely you are the victim of buying China junk. It's hard to avoid lately.
black33ford
Apr 10, 2025 06:38 PM
Flattieflounder
Dec 22, 2022 10:18 AM
elroy6468
May 13, 2015 04:23 PM
pops_91710
Jan 9, 2014 02:54 AM
davewave649
Aug 22, 2012 03:27 AM
