E350 E4OD OD issue
Anyway, like WCM says, your problem at hand is no tach signal. Make sure you don't have any blown fuses in the under hood fuse box. Two of them can blow and cause no tach.
WCM also has ya right on, that 11 is what you want and 23 is probably now just because you didn't hold WOT during the whole scan.
No more code 63 and 67 is GREAT news! (those were your main issues) It may be hard to believe right now, without a working tach, but you did just fix two major problems. Just check the fuses and or test the tach and you'll be ok now more than likely. It can't shift worth a lick without that working, so no surprise there.
Let me see here, fuse U and I seem to recall if K blows you lose your tach too, but just check them all. If you blew fuse K the engine wont start due to that being the FSS line, so you'd know. I dunno, I know there are two and I know U is one of them. Just check them all. Does the engine start? You were right in the area and so you could have shorted something out there without realizing it.
I dunno how this relates to the vans. Use it as guide to figure it out, if not the same or google search to find E-series if it looks all different..........or just check all the fuses under the hood you can find and just replace any blown ones haha........
Oh the other one is probably fuse I actually......and don't forget, the tach wires often chafe right there on the vac pump. If you were right there working, maybe you leaned on them and shorted them out. Check the wires going to the tach before replacing a blown fuse. I'd bet something like this happened, because what are the odds the tach died all the sudden, right? Could be as simple as putting some tape around the wires and replacing a fuse. If I remember right, on the F450 where I left the vac pump, I think I put some wire loom around my tach wires right there, to help prevent the common issue.........If I didn't I should have....and anyone else reading should do the same.
Ah, yes. Found a pic. I did in deed do this years ago. I can see the wire loom. I probably have zip tied so it can't vibrate either.
Preventative side note; there's also another common wire chafe area in the 9th gens for the trans; the shift handle wires going to the OD cancel switch. I have both trucks wire loomed in there to prevent this also. You have to remove the key lock and shroud around the steering wheel to get in there to do it, but it's worth it.
That's good news about the codes. I ran the test again with the throttle depressed and did not get a code 23, so all is good there. Both the TPS and neutral safety switch were original so needed done anyway. So this is something that won't send a code.
I'm going to check the resistance of the solenoids through the plug tomorrow. I need to leave by 2 tomorrow, so I'll have to see what I can get diagnosed.
About the tach signal. There is not a dash tachometer in the E-series. It was my understanding that the sender on top of the timing cover was optional. When I decided wanted a tach, I found that the sensor was already installed. It has 2 black wires, one grounded on the intake manifold and the other was just cut about 12 inches from the sensor. Considering that there were also sensors for other gauges with cut wires, and evidence of extra gauges mounted to the dash, I assumed that it had an accessory tach at one time given it's use driving a PTO. If the transmission has been fine until now, why would this happen suddenly while driving ? Is there another tach sensor for the E4od ?
I'll go through the fuses again tomorrow.
John
And FWIW I wouldn't replace the small T-15s with Allen heads only because I have had way more stripped out allen head fasteners than torx bolts. Yes the T-27s can be a nightmare and I had to use a chisel to remove one of mine, but even after mangling it the Torx portion was technically still usable but I replaced them both with Grade 8 hex bolts and lock washers. You can make small adjustments to the TPS by loosening the two smaller bolts and moving the TPS around. The TPS is so sensitive to movement that the large bracket is used to get it close and then the small bolts can fine tune the setting. If you pay attention you'll notice the holes for the small Torx bolts are a hair over-sized and that is what allows for fine tuning like moving it from 1.16 to 1.2.
Is there a test strategy for checking these things once one has cleared up the code related issues? (Besides fixing the tach lead). Again, everything was fine, then I turned a corner and was accelerating and suddenly this started...
John
So, as you can see here, dark green goes down to pin #44 for RPM negative input to TECA
Then tan with yellow stripe, goes down to pin #4 for RPM positive input to TECA
Tach sensor upper left by the large A
Hey, the aftermarket is finally making IDI tach sensors? Only took about 30 years haha
It came from a Government auction at the Idaho National Laboratory, the US nuclear research facility.
It is one of the first thousand of the 92 new body style vans and was built as an RV unfinished chassis, then sent to Anderson All Wheel Drive for conversion. The drivetrain is a 91 F350 pto transfer case w/Dana 60's front and rear. Front is a kingpin axle.
It had a crane inside, powered by the pto, that folded out and ran sensors up and down boreholes looking for radioactivity. The crane mounted through the body to big frame brackets. All that was removed and a cover plate added where the pto was.
Then it got used as a cyber security test vehicle, spoofing cell towers. I still have not removed all the antennae.
It didn't want to start the day I bought it because the glow plug relay wires were cut too. A brief shot of either got it started and I drove it three hours home. Restarts easily once warm. The more it's been driven the better it runs...until now.
I think I'll be driving my spare car back tomorrow.
Here is how to see if the coast clutch solenoid is doing what it is supposed to do. First, get into overdrive. Lift off the gas. As the vehicle slows, when it shifts to 3rd gear does the engine speed stay up, providing engine braking, or does it drop to idle speed? It should drop to idle speed.
Now go back to a speed fast enough that it's in overdrive. Lift off the gas and press the OD OFF button. Does the engine speed stay up, providing engine braking, or does it drop to idle speed? In this case, engine speed should stay up.
Ok, so it's not the coast clutch solenoid.
When I parked it I checked the codes again. Only got "11" so that is good. Last I drove it (TPS set at 1.19), it shifted very high, I had to lift my foot off the fuel to get it to shift.
Also, when this first happened, I turned off the OD button and it behaved normally, at least to me, pretty sure there was braking.
What other tests can I run? I'm planning to head back next weekend, I'd like to have a plan/parts together by then.
Also, is this the Tach connector? The leads for the original were cut off and used for an accessory tach, you can see them in wire wrap heading towards the rear. If this is the body-side connector, I'll buy a new one and install it...but I'm skeptical.
That looks like the TECA side of the tach plug, but of course if you could source a plug to wire back up to your tach sensor from a salvage yard or replace the sensor with a new one, you could see if it just plugs in. I mean, skeptic or not, you're trans needs the tach signal. You're going to need the plug/new sensor w/ one. It might have shifted somehow before, but it couldn't have ever shifted correctly.
OK, new tach sensor ordered...
I was just about to suggest something similar! It seemed to me the old TPS was set very low and that the system was fudged somehow, like over-riding a limp-home or something.
I'll fix the tach first thing when I get back there again and start over with the TPS adjustments.
Plus, the fluid was really grungy for only 60K miles! Could this have caused pre-mature plate wear?
Is there a back-up idea if the new lead doesn't do it?
John
I'm going back in 2 weeks for a longer stay when I can spend some more quality time with the TPS. Is there any thing else I can do /check/replace while I am there?
