New motor oil pressure question
Old Apr 1, 2025 | 08:39 PM
K5BEAST's Avatar
K5BEAST
Just installed a brand new 5.4 in my 09 superduty. Per manufacturer's instructions I disabled the ignition via unhooking the CKP and cranked the motor over in attempt to build up oil pressure. The instructions state to do this until pressure registers on the gauge inside the cab.
problem is, I've cranked and cranked it and am showing no pressure on the gauge inside. Can anyone confirm that the gauge will even register pressure prior to the motor running? I really don't want to try and get a manual gauge connected as this motor is a bear to work on as I'm sure lots of you know.
thoughts?
Old Apr 2, 2025 | 12:18 AM
K5BEAST's Avatar
K5BEAST
Update: removed oil pressure sensor and used a transfer pump to pump a few quarts of oil in there. Cranked it over a couple times, still not reading pressure on the gauge. Decided to fire it up for a second and the pressure immediately registered on the gauge.
It fired right up! No codes, no misfires. Small exhaust leak but I can fix that!!
I call bull**** on the whole using the starter to prime it method.
Old Apr 2, 2025 | 03:41 AM
RLXXI's Avatar
RLXXI
You likely just had a trapped air pocket, it's most definitely not bs. I've built many many engines over the course of my 40+ year career in this business and have always cranked the engine before starting it to get oil up to the top of the engine where it starves for oil the most on initial start.
Old Apr 2, 2025 | 08:30 AM
projectSHO89's Avatar
projectSHO89
More likely than not, the oil pump simply wasn't able to make enough pressure at cranking speed to trip the pressure switch. Usually around 4-6 psi is needed to do that.
Since it's fired up and running, it's now a moot point for this engine.
Old Apr 2, 2025 | 04:43 PM
RLXXI's Avatar
RLXXI
Pressure isn't the objective, presence of oil up top is.
Old Apr 2, 2025 | 07:19 PM
projectSHO89
Funtionally, absolutely. He was asking about the lack of the oil pressure indication while cranking. The "idiot" gauge requires a minimum pressure in order to register mid-scale.
Old Apr 2, 2025 | 08:37 PM
90Ford73's Avatar
90Ford73
Haven’t tried the 09, but my ‘10 f150 5.4 will register oil pressure by cranking over. It sat for quite awhile, so I just wanted to build some oil pressure before firing. Probly not relevant, but doesn’t hurt anything
Must’ve been an air pocket maybe, every engine with a healthy battery and starter should be able to build oil pressure by cranking I would think
aprice
Jul 13, 2010 04:57 PM
mabigredtruck
Feb 28, 2008 11:14 AM
TheTinian
1978 - 1996 Big Bronco
19
Aug 14, 2007 02:54 AM
ford79man91
Oct 10, 2006 12:06 PM
abendx
Jan 15, 2003 06:15 PM
