Quench heads or a turbo?
Ok all, i have a delimmia here. I can't decide on weather on not to go with quench heads or a turbocharger setup. I have a 73 4V clevo (4 bolt main bolt) and i want more power so i can run a low 13s 1/4 with my 3:1 rear gears in my truck. Now i have the quench heads (but they need to be clean of rust so i might do a mild port and polish while i'm at it and a 3 angle valve job to) sitting in a shed ready to go. The turbo i would need to get but i would either use twin t3's or some kind of a diseal turbo. If you were me what would you do? I need to decide cause the i will be swaping motors and putting the clevo in my truck.
P.S. there are pictures of the motor in my gallery and a pictures of a turbo off a 855cu in 6cyc cummins diseal in there to.
I think the turbos on those 4V quench heads would work great. I don't know this for an absolute fact but it makes sense that the large intake ports of the 4V C heads would respond very well to a forced induction system. I think the sooner you could get the boost in the better it would be so I'd think 2 smaller turbos would be your best bet.
A very mild cleanup of the heads would be your best bet. I'd make sure to unshroud the valves, polish up the combustion chamber, smooth out the ports and get all of the casting flash and restrictions out of the valve pockets. Off hand I don't know if the 73 heads had the thermactor bumps in the exhaust ports but if it does make them go away as well.
jeremy5wilburn
10-12-2016 04:23 PM
79-F350
05-03-2014 12:23 PM
351Cleveland C4
13
03-07-2014 06:59 PM
Blown 331
01-29-2006 04:21 PM
