Keyless entry stopped working
Old Mar 31, 2025 | 04:32 PM
TestPilot57's Avatar
TestPilot57
It MAY have been after I got my truck back from the dealer. I mean, it WAS, but it MAY not have been immediately. Hard to tell, as about the only time I lock my truck is when I am remote starting.
Anyway, it's always worked before, stopped in the last few days. Can't lock or unlock except with the fob or button on the door.
I've checked all the "features" and "settings" to see if there is a user selectable option that may have gotten changed and can't find one. Is it back to the dealer, or...?
Old Mar 31, 2025 | 04:41 PM
Jdubsworld's Avatar
Jdubsworld
2nd Gear
Had the same thing happen last week after a service on my 2023 250, The dealer said it must be a coincidence I got home from service and waited a few hours, went back out and it was working again. Have not had any issues since.
Old Mar 31, 2025 | 05:14 PM
TestPilot57
Got the truck back Tuesday. Has been not working since at least Friday.
Old Mar 31, 2025 | 05:52 PM
Split rims's Avatar
Split rims
Probably the BMS disabling it to save the battery.
Old Mar 31, 2025 | 06:17 PM
TestPilot57
I am driving the truck almost every day, 20-30 miles, and it was driven back from the dealer 40 miles before I drove it home that day.
I have, in the past, left the truck for 2 weeks and all it disabled was access from the app.
Old Mar 31, 2025 | 06:40 PM
Split rims's Avatar
Split rims
When I had a 2021 bronco sport, it would occasionally happen to me.
This was after driving over 200 miles a day.
The System truly sucks.
Old Apr 1, 2025 | 06:16 AM
Philly35's Avatar
Philly35
Try unhooking the battery for 20 minutes. It doesn’t matter if you drive it everyday. The battery’s in these trucks a re super finicky when it comes to voltage and they are crap.
Old Apr 2, 2025 | 05:47 AM
TestPilot57
Disconnected it for an hour or so. No change.
Old Apr 2, 2025 | 06:29 AM
Tsax6010's Avatar
Tsax6010
Do you have dual batteries? Both negative cables need removed to cut power if the BCM reset is the fix for your issue.
Old Apr 2, 2025 | 07:49 AM
TestPilot57
I have a single chassis battery, but I understand that the 2KW pro-power has a second battery (or maybe 2?) behind the rear seat. I seem to recall that it's 24v though, so I assume not tied into the chassis battery system.
Old Apr 2, 2025 | 08:46 AM
Tsax6010's Avatar
Tsax6010
I have a single chassis battery, but I understand that the 2KW pro-power has a second battery or maybe 2?) behind the rear seat. I seem to recall that it's 24v though, so I assume not tied into the chassis battery system.
Correct. Those batteries are not tied into the 12v system and are dedicated to the inverter.
Old Apr 3, 2025 | 10:56 AM
TestPilot57
Not sure if this is related, but I just remote started the truck, unlocked it with the fob, and about 5 seconds after I opened the door the engine shut off.
In my wife's Telluride, if it's remote started and one of the doors other than the drivers door is opened first, it will shut off if the drivers door is not opened by then. But this has never happened to me before. I had not even settled enough to reach over and grab the door to shut it...
Old Apr 3, 2025 | 11:09 AM
Fox-BLUE1's Avatar
Fox-BLUE1
You could try the reprogramming procedure outlined in the manual. Might help and might not, but worth a shot before having to take it back to the dealer.
Old Apr 3, 2025 | 11:10 AM
Tsax6010's Avatar
Tsax6010
How long has it been running for between you initiating the remote start and getting in? By default I think the remote start running time is only like 10 minutes.
Old Apr 3, 2025 | 01:24 PM
TestPilot57
It was less than 1 minute. Probably 30 seconds. I didn't "need" to pre-start it, I just like to have it running enough that the idle is back down to "normal" before I take off. It was already moderately warm from having been driven and fully warm about 2 hours before. I often do that - remote start it on my way when it's only 50-100' away.
