CORRECT YEAR
Old Mar 31, 2025 | 11:13 AM
Chewedup1964's Avatar
Chewedup1964
8th Gear
CORRECT YEAR
I have a 1990 F-250 Vin# 1FTH26G9LKA84584
I went to purchase a new Fuel Pump relay and the one they had was not a match for what i had.
They brought out a FPR for a 1989 and it was a match.
SO when i need parts for the truck should i ask for 1989 parts or 90?
THANKS
Old Mar 31, 2025 | 12:32 PM
Scndsin's Avatar
Scndsin
What's the build date on the door data plate?
Any emissions stickers under hood should call out the year.
Some ford parts are build date specific.
EDIT, if your vin starts with 1 F = 91, so there's that
Old Apr 1, 2025 | 08:32 AM
manicmechanic007's Avatar
manicmechanic007
THANKS
You can ask for anything from a 1986 to a 1991
They are all the same relay (# 19991 at Autozone)
Factory fuel pump relay was green
'92 and newer it's a square ISO relay
Old Apr 1, 2025 | 09:30 AM
1Butcher's Avatar
1Butcher
That's not a good VIN.
Old Apr 1, 2025 | 10:05 AM
wwhite's Avatar
wwhite
That is incorrect.
If it start with a 1, 2 or 3, it is made in USA, Canada or Mexico.
The start digit has nothing to do with the year.
Old Apr 1, 2025 | 10:08 AM
1Butcher's Avatar
1Butcher
8th digit is the year. Depending on the time, a letter was used. Right now, the year is in letters. A is 2010, B is 2011, etc.
Old Apr 1, 2025 | 10:11 AM
wwhite's Avatar
wwhite
Correct VIN:
1FTHX26G9LKA84584
Old Apr 1, 2025 | 10:15 AM
wwhite's Avatar
wwhite
Incorrect, 8th digit is the ENGINE code.
The model year is the 10th digit, L = 1990.
Old Apr 1, 2025 | 10:18 AM
1Butcher's Avatar
1Butcher
Sorry, 8th from the end. That is how I look at every VIN, maybe not the right way, but it's easier for me. I stand corrected.
Old Apr 1, 2025 | 10:26 AM
wwhite's Avatar
wwhite
It is not easier, it is the incorrect way, as there is only one way to look at 17 digit VINs.
It is a universal standard for 17 digit VINs.
Ford VIN numbers are broken down to 9 sections:
  • 1-3rd character - Manufacturer Identifier
  • 4th character - Restraint System
  • 5-7th character - Make/Model/Series/Body Type
  • 8th character - Engine
  • 9th character - Check Digit
  • 10th character - Model Year
  • 11th character - Assembly Plant
  • 12-17th character - Sequential Production Numbers
VIN digit position
#1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
1 F T H X 2 6 G 9 L K A 8 4 5 8 4
Old Apr 1, 2025 | 10:34 AM
1Butcher's Avatar
1Butcher
At my age, it's easier FOR ME, to count backwards. The digits are small. Most of the VIN's I look at have 6 numbers at the end. So I look at the last number [actually the first] and go back two digits. Faster than starting at the beginning and counting 10 digits.
But, I will not despite the fact that the 10th digit is the year. How you find that digit, is up to you. I choose to do it the 'incorrect' way.
Old Apr 1, 2025 | 10:52 AM
wwhite's Avatar
wwhite
I understand, but its not a count, its an ordered placement.
Old Apr 1, 2025 | 11:05 AM
1Butcher's Avatar
1Butcher
What you call it is up to you.
Why do most people call it a water pump, when it does not pump water? It's a coolant pump, that is what it actually is. We all are talking about the same part [and we know it] but I am not going to critique what peoples choice of words use when we all are communicating just fine.
I'm just a dumb mechanic and although try to make everything in my head be in harmony, I appreciate everyone's differences. You call it whatever you want to make harmony in your mind, just like I have to accept everyone calling it a water pump.
Old Apr 1, 2025 | 01:24 PM
manicmechanic007
Missing an F in the vin?
Should start with 1FTHF
Old Apr 1, 2025 | 03:54 PM
wwhite's Avatar
wwhite
It's kinda documented in like EVERY Ford manual ever to exist.
You should learn how to read a VIN correctly, then maybe you could help someone who cannot.
If we all read the VINs the way the book says, and which most of us do, we wouldn't be having this conversation about water pumps.
Just trying to help the OP out, not confuse them.
