king pin greasing problem
Old Mar 30, 2025 | 07:03 PM
Hwolfe815's Avatar
Hwolfe815
5th Gear
Has anyone else have a problem with greasing the king pins ? if so what did you do to cure the problem?
Old Mar 30, 2025 | 08:31 PM
Franklin2's Avatar
Franklin2
Take the fitting out and see if you can dig it out with a sharp metal object. Clear it out as best you can, re-install the fitting and see if it works.
Old Mar 31, 2025 | 04:36 AM
s1120's Avatar
s1120
If the fitting is clear, Ive had some that would take grease better if you jacked that side off the ground. They also make the grease injectors now. Its like a punch filled with grease, and you put it on the fitting, and hit it with a hammer to force the grease in.
Old Mar 31, 2025 | 05:37 AM
FuzzFace2's Avatar
FuzzFace2
I grease mine jacked up so the grease can get to the side that has all the weight on it.
The pins maybe frozen and not take grease and the only fix is to replace them and keep them greased.
Dave ----
Old Mar 31, 2025 | 08:37 AM
Max Capacity's Avatar
Max Capacity
Not sure it will help with your issues, but I use these on my grease gun.
https://locknlube.com/collections/lo...grease-coupler
RTT
Jul 23, 2023 07:07 PM
Roger w jr
Jun 4, 2022 11:10 AM
Tell falcon
Sep 1, 2021 09:45 PM
Auger Hekla
Aug 19, 2017 02:58 PM
windsor8689
Feb 15, 2011 09:26 PM
