Synthetic?
Old Mar 30, 2025 | 08:25 AM
2017-350's Avatar
2017-350
Synthetic?
Is synthetic oil worth the extra cost? 2024 F350 HO...i change oil, filter and fuel filter every 10,000 miles.
Old Mar 30, 2025 | 08:47 AM
ssls6's Avatar
ssls6
If you plan on keeping the truck long term, and you plan to stick with 10k mile change intervals, I would say yes to your question.
Old Mar 30, 2025 | 08:53 AM
simplemike's Avatar
simplemike
8th Gear
I would get an oil sample done to see if it should be changed at a lesser mileage.
Old Mar 30, 2025 | 11:44 AM
drew999999's Avatar
drew999999
I'd say for a $12k engine, the cost for synthetic is a no brainer. If you do your own oil changes at 10k, $110ish for 4 gallons of Rotella T6 plus another $25-30 for a Motorcraft filter is cheap compared to the overall cost of the truck. As I daily drive, my oil monitor has me changing about every 7500 miles. I'll also do fuel filters annually as it'll just be my normal annual maintenance schedule for air filters, etc.
Old Mar 30, 2025 | 04:40 PM
Painted Horse's Avatar
Painted Horse
I use Valvoline Premium Blue 5w40 full Synthetic.
Look at my last oil test that I've included below.
I did not test the oil that came in the truck and was changed out at 5,000 miles.
The first oil change on the sheet at 13,244 miles was Motorcraft 10w30 that the dealer installed at my oil change
Every change since that, I've done at home with Valvoline.
some of the differences in values can be attributed to break in, But I think most of the differences in values are type of oil and additive package each contained.
Bottom line, My trucks seems to do ok with 10,000 mile oil changes on Full Syn oil
Old Mar 30, 2025 | 05:10 PM
Split rims's Avatar
Split rims
https://www.ford-trucks.com/forums/1...nv-vs-syn.html
Very good video comparison.
Old Mar 31, 2025 | 05:59 AM
NDanecker's Avatar
NDanecker
Yes but only after motor breaks in and rings seat. I’d hold off until 10k miles or even 2nd oil change and only then go full synthetic. Do some heavy towing to build boost after initial heat cycles for drive train (1000 miles or so) before towing.
Old Mar 31, 2025 | 07:15 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I have been running Rotella T6 synthetic in every diesel I've owned for about the last two decades. I honestly don't see why you wouldn't if you want to run longer OCI.
Old Mar 31, 2025 | 10:40 AM
Leardriver's Avatar
Leardriver
Synthetic oil is the technology of today. For a vehicle built this century, dino oil would be a step back in performance.
Old Mar 31, 2025 | 12:15 PM
Wyoming Don's Avatar
Wyoming Don
Trailering
Fairly Graphic in the illustrated benefit. I'm a Shell Rotella T6 fanatic. Over the 3 diesel SDs, over 600,000 miles total - no issues with engine internals. I don't push the mileage intervals - probably 7,500 between changes on average. Not a 10,000 mile guy. The filter gives up before the oil at that point.
Don Expedition
2015 - 2020 F150
Jun 11, 2020 05:55 AM
Coalroller
43
Nov 7, 2010 09:46 AM
buckaroobonzai
Aerostar
15
Sep 21, 2005 06:10 AM
lakewood11
1983 - 2012 Ranger & B-Series
Mar 23, 2005 03:11 AM
MJW
15
Sep 22, 2003 06:58 AM
