Sponsored by: Real Truck
ABS System retro-fitting
Old Mar 29, 2025 | 03:03 PM
Jack Pine's Avatar
Jack Pine
5th Gear
I'm just starting this conversation/learning process, so please be patient with my ignorance when it comes to this topic, I'll catch up quickly though if you give a chance ;-)
OK here is what I'm doing. I am retrofitting a classic '71 cab onto a 2011 superduty F350 rolling chassis.
All the ABS equipment/system/computer/harness remained with the chassis that I bought. All the brake lines and sensor wires to each wheel has remained intact, as well as the rear diff wheel speed sensor.
I'm wanting to know has anyone ever pulled this off? "This" being simply putting power to the system and giving it a go?
How do I learn more about the ABS system without needing to become an Ford electrical engineer?
Is it possible that I can just power this system up and it just starts working without the original 2011 cab?
My intentions are to put a new 2011 (same yr as the chassis I bought) hydro-boost master cylinder on the truck when the cab is installed...fyi.
Y'all can see I'm at the very beginning here, anything pointing me towards more info would be more than appreciated!
Thank you -JP
Old Mar 29, 2025 | 03:31 PM
ifrythings's Avatar
ifrythings
Is this a SRW or DRW chassis?
Unfortunately putting power to it won’t do anything, it needs the CAN bus system to tell it to turn on, when the brake pedal is pressed, if the brake fluid is low, if it’s in 4x4 and a bunch of other things.
There is another option you could do but you have to verify if it really has a rear diff sensor or if it’s the locking diff plug your seeing, is there any wheel sensors at the rear wheels?
Old Mar 29, 2025 | 07:33 PM
Jack Pine's Avatar
Jack Pine
5th Gear
Thank you for response!
It is a Dana M80 DRW rear end, and yes that is definitely called a speed sensor coming out the top of the diff housing, FYI it's a spicer part #4221458. This particular diff does not have an electric locker either.
Yes all the wheels/rotors have sensors on them.
I'm all ears in regards to this second option Mr Things!
Old Mar 29, 2025 | 07:48 PM
ifrythings's Avatar
ifrythings
In that era the dually’s had 3 channel 4 wheel ABS, both front wheels will have a sensor and the top of the diff also has a sensor. The SRW trucks had 4 channel 4 wheel ABS, with 4 channel, all wheels have a sensor and there is no sensor in the top of the rear diff.
Now this works in your favour if you want to keep ABS but you have to use a unit from 2002-2004 trucks as its stand alone and has the inputs required to work, you’ll also have to swap out the all the sensors to the older generation for this to work.
I did this with my 95 F350 when I swapped in 2006 axles and it works like factory ABS. You can not use 05-09 ABS units either as they are also CAN bus controlled.
Old Mar 30, 2025 | 07:55 AM
Jack Pine's Avatar
Jack Pine
5th Gear
Oh my gosh what a fabulous response, this is exactly what I came here for, thank you so much!
I went out and confirmed that Indeed it is a 3 channel system.
Now I suppose the next order of business beside sourcing the parts to start working through it is figuring out the wiring/circuitry.
Old Mar 30, 2025 | 11:20 AM
ifrythings's Avatar
ifrythings
Wiring is fairly simple, good source for wiring diagrams https://charm.li/Ford/
Estam
Nov 16, 2019 10:43 PM
jonesg
31
Aug 15, 2014 08:31 AM
89fourx4
Sep 19, 2007 08:36 AM
Muddog999
1983 - 2012 Ranger & B-Series
May 19, 2007 05:29 AM
Wakeboarder141
1978 - 1996 Big Bronco
Mar 9, 2003 08:23 PM
