Sponsored by: Real Truck
Rearend replacement
Old Mar 24, 2025 | 11:04 PM
Tony Ricci's Avatar
Tony Ricci
Rearend replacement
So this happen to my rearend...broken bolts on axle ring. Other then bullet to the head ...any advice.... can just those be replaced or whole rearend ? It's a 2004 e350 super duty van...it used to be an old news broadcast van
Old Mar 24, 2025 | 11:34 PM
Truckwardo's Avatar
Truckwardo
Differential specialty shop is where I would go. Get their estimate. Where I live you could be looking over 1k. Some guys in the States could sort it out for half that.
Old Mar 25, 2025 | 10:36 AM
Eman85's Avatar
Eman85
Everything can be fixed. Most don't know how to replace the parts or don't have the proper tools so they find a used complete rear. Also parts get expensive plus the labor so it may be cheaper to replace with a used rear. There is a sticker in the door opening and it will have an axle code or there should have been a tag on the rear itself. That will tell you the ratio and you can check used parts yards.
Old Mar 25, 2025 | 02:31 PM
crashz's Avatar
crashz
Did the news team lay rubber getting to a story? Jeeze - I've never seen that!
Kazoom
Mar 22, 2025 03:33 PM
Tony Ricci
Mar 12, 2025 06:43 AM
THull21
Sep 26, 2023 03:22 PM
ogarcia434
Mar 9, 2016 06:08 AM
