yup they have them in various temps etc
250 is pretty..high
It might not be an issue using pump at pre start
then once its shut down.
no hot oil is running through????
Definitely not mount pump near exhaust
I will be running an oil heater even in the summer, so in my use case the pump would see hot oil, not to mention hot starts, it takes oil a while to cool, and if i put a pre lube pump in I plan to use it on every start .
