E4OD...
Old Mar 23, 2025 | 05:40 PM
Kinster's Avatar
Kinster
7th Gear
E4OD...
I was driving down a hill when i looked behind me and saw lots of smoke, i pulled over and looked under my truck and it was dumping out oil from what i assume was the rear main seal, thats all i know at the moment. i took off the little black inspection cover on my transmission and found some metal pieces, there was engine oil in the transmission and transmission fluid in the engine. But i have no idea what these pieces are:
Old Mar 24, 2025 | 05:58 AM
69torino's Avatar
69torino
Catastrophic failure is my guess. What your and model is your vehicle ? E40D transmissions could be year specific depending.
Old Mar 24, 2025 | 05:17 PM
Kinster's Avatar
Kinster
7th Gear
it is a 1991 ford f150 supercab xlt lariat 351w efi 4wd
Old Mar 24, 2025 | 05:53 PM
JJF20's Avatar
JJF20
Don’t recognize anything in that pic.. Post pictures of the transmission, engine and truck if you can.
There is no connection or direct way for trans fluid to get into the engine, or vice versa. You may have a pump leak at the same time as a rear main seal leak. They are not connected and cannot force fluids into each other.
Old Mar 24, 2025 | 08:28 PM
Kinster's Avatar
Kinster
7th Gear
These are all I have at the moment
Old Mar 24, 2025 | 08:46 PM
Junktownbill99's Avatar
Junktownbill99
Originally Posted by Kinster
Nice truck
bart f-350
71
Jul 31, 2023 03:24 AM
rterril02
Nov 3, 2016 09:22 PM
BobnSofi
Jun 8, 2011 11:06 PM
nebraska_e28
1978 - 1996 Big Bronco
Nov 24, 2008 02:54 PM
yalebldg
May 20, 2003 11:15 PM
