Another additive test
if the test is to measure lube or to measure soot reduction via ctane improvement or to measure water removal or to measure cold weather flow….who gives a hoot that the additive has trace elements that compare to the ingredients of coolant. …..who’s pay this guy.
Run ATF in fuel to clean injection system
Most additives dont work but adding in 2 stroke oil has kept my IDI and HEUI engines running better
Yes even the gas ones with a carb gets some as well so the carbs will have an oil film instead of corrosive alcohol when shut down.
