General Diesel Discussion
Another additive test
Old Mar 22, 2025 | 09:23 AM
Split rims's Avatar
Split rims
Here you go....
Old Sep 6, 2025 | 10:58 AM
speakerfritz's Avatar
speakerfritz
Not a good test senerio
if the test is to measure lube or to measure soot reduction via ctane improvement or to measure water removal or to measure cold weather flow….who gives a hoot that the additive has trace elements that compare to the ingredients of coolant. …..who’s pay this guy.
Old Sep 9, 2025 | 11:00 AM
knottyrope's Avatar
knottyrope
been running diesels for almost 20 years
Run ATF in fuel to clean injection system
Most additives dont work but adding in 2 stroke oil has kept my IDI and HEUI engines running better
Yes even the gas ones with a carb gets some as well so the carbs will have an oil film instead of corrosive alcohol when shut down.
Old Jan 17, 2026 | 09:22 AM
1987cabplus's Avatar
1987cabplus
As a Truck driver with 24 years rolling my take.Yeah started in a 95 ihc cabover 60 series detroit.2nd was a 97 ihc 9400 daycab M11 cummins( my fav). On All the additves,I only recommend 2 with Real results and or zero negative effects.Power Service ( Grey bottle) and Seafoam are what I had the best experience with.Mpg is gold in the big diesels, and a noticeable power gain,and these Work.While i transition to Volvo in 09 vnl daycab D13 (400hp) the emissions mostly knock sensors= def always failed.My 12 Volvo rocked with a 10spd with 3 55 rears( power service ruled) Mpg and improved power, Zero injector issues or cold start struggles.Stepped into a 19 Volvo 12spd auto tragic but it was pretty strong on mpg 8mpg average,but achieved higher like 9-9.5 power serv. Again.Last year got my 1st New truck ever.25 IHC LT with the IHC S13 ( 400hp) 14spd auto.Whole molly mpg is insane,no matter the load.Yes power serv. Not alot but sometimes.Pic I'm showing is 358miles went from nc- sc and back empty/ loaded with a Reefer load was 27k .Wow.Point is PS Grey is king ,Seafoam is great, but have to add 2 bottles for a See it benefit mpg.figured i would show my Truck
IB Tim
Oil & Lubrication
May 15, 2013 02:22 PM
