2nd row
Old Mar 20, 2025 | 09:38 AM
NCShooter00's Avatar
NCShooter00
2nd row
Can someone post a picture of the passenger side 2nd row folded up? Like below. This rod came with the vehicle loose under that seat. I'm unsure of the orientation & would like to be able to slide that seat like I do the drivers side. Or am I missing a piece for that?
Old Mar 20, 2025 | 09:40 AM
NCShooter00
This metal rod with the white plastic is loose as well. Attached on the upper portion but loose on the bottom
Old Mar 20, 2025 | 09:49 AM
NCShooter00
Further investigation. Wth is this wire
Old Mar 20, 2025 | 03:27 PM
01__Excursion's Avatar
01__Excursion
That coat hanger looking wire is your new seat release in place of those detached rods.
Old Mar 20, 2025 | 04:55 PM
John in OkieLand's Avatar
John in OkieLand
mine does not slide forward/backward.
it will only Fold Down, which is where it stays forever,
my kids are in their 50s now
Old Mar 20, 2025 | 05:52 PM
4Kids's Avatar
4Kids
The Struggle Bus¯\_(ツ)_/¯
This usually because the rod that connects the release mechanism to the handle is bent from over-zealous users. Take a pair of pliers and bend it back into shape so the latch fully disengages when the lever is pulled.
Old Mar 21, 2025 | 11:02 AM
01__Excursion
Old Mar 21, 2025 | 02:00 PM
NCShooter00
Thanks for that. I had it apart yesterday but then put it back together bc I had to get the kids. I'll use your pic for reference when I tear it back apart
Old Apr 1, 2025 | 10:36 AM
EX2000XLT's Avatar
EX2000XLT
5th Gear
For anyone coming across this, the Dorman HELP door actuator plastic clips work for this. They will fix the loose rods. Insert the clip into the hole, slide rod through the clip and mounting hole. The clip then inserts onto the side of the rod. I still need to find a replacement spring that works.
moates49
Oct 30, 2023 08:00 AM
Centennial F100
Aug 13, 2023 06:14 AM
Doug Savage
Apr 6, 2022 10:15 PM
95fiveoh
18
Mar 25, 2020 11:22 PM
newguy399
Oct 31, 2015 11:28 PM
