Cp4 health
Old Mar 18, 2025 | 11:34 AM
speakerfritz's Avatar
speakerfritz
Cp4 health
Just posting today’s cp4 health status
last line
requested vs actual is almost spot on.
Old Mar 18, 2025 | 12:06 PM
kayakingpoodle's Avatar
kayakingpoodle
I think you should monitor the duty cycle of the metering valve too, if you can, the commanded vs actual will be super close as long as the metering valve can make it happen, as the pump output goes down the duty cycle of the metering valve will increase to compensate until it can't and then you will see disparity in commanded vs actual pressure.
Kind of like the old tbi systems with IAC motors and idle issues due to passage coking from the egr. Just check the IAC counts while scanning for codes and you'd know if it was time to decoke the throttle body.
Old Mar 18, 2025 | 02:29 PM
jollyrogr's Avatar
jollyrogr
Also it is easier to maintain pressure at no load. See how it maintains pressure under load.
Old Mar 19, 2025 | 11:24 AM
Gladstone's Avatar
Gladstone
Good idea looking at command vs actual. I think checking maximum rail pressure at full load is also a good diagnostic. If the peak pressure degrades even though at lower pressures command is close to actual its a sign the pump may be in trouble. My 2024 peaks at 36.9K psi.
Old Mar 19, 2025 | 11:26 AM
acdii's Avatar
acdii
Needs a cleaning, fuzzy.
Old Mar 19, 2025 | 03:52 PM
augam's Avatar
augam
Interesting
Old Mar 20, 2025 | 02:51 PM
Stinson1's Avatar
Stinson1
I monitor A vs D while on long trips from home and while towing. I have an S&S filter kit, so I want to know that my pump is failing before it locks up and spins my crank gear turning into an entire engine replacement. I think this is the major flaw with the disaster prevention kit not too many people talk about. While it is nice that my truck will still start and run with a failing pump to get out of traffic or off the roadway, it is at a risk that it spins the crank gear.
Old Mar 21, 2025 | 08:43 AM
jollyrogr's Avatar
jollyrogr
I have actually never heard of this. Just another reason to go DCR I guess. My S&S DPK has the Racor return filter which I like so that I can monitor the media to see if there's any glitter in there.
adrose211
6.4L Power Stroke Diesel
Apr 14, 2024 02:03 PM
elkhart75839
Apr 3, 2024 07:51 PM
CelticOne
Nov 13, 2020 08:08 AM
dustybumpers
Maryland Chapter
Sep 6, 2010 06:16 PM
bronczilla
Offroad & 4x4
May 7, 2003 03:00 PM
