Sponsored by: Real Truck
Need help with diag
Old Mar 17, 2025 | 03:31 PM
6.7Newbie!'s Avatar
6.7Newbie!
1st Gear
Need help with diag
I have a 2013 ford f550 super duty service truck, with nothing on the ignition, cluster, lights, I've checked all the fuzes and relays and replaced some, checked ignition switch it gives me power, replaced batteries and im stuck on this.
Old Mar 17, 2025 | 03:57 PM
ifrythings's Avatar
ifrythings
First thing I would check is the BCM(interior fuse box), seen way to many of them get watered by a leak on the passenger side dash and then all the plugs get corroded and nothing works. I would pull as many plugs as you can and look for green/white corrosion.
BWilcox
Sep 16, 2022 05:06 PM
Jabshire
Mar 27, 2021 05:40 PM
MensaGirl
2004 - 2008 F150
May 13, 2018 05:36 AM
robert paul
May 26, 2008 01:41 PM
