‘82 F100 Handling
History, new to me f100 2wd 4.9l 4spdOD. I live in rural central Texas east of Austin. I have several older and newer fords as well as a Tacoma. This is my first F series and thus first twin I beam.
Many of the roads out here are extremely lumpy, cracked and potholed. This is due to bad soil(black lands) heavy farm equipment and lack of attention from the county. All of our cars handle it pretty well, we avoid potholes and uneven surfaces due to cracks but we’re always subject to lumpy and uneven surfaces both perpendicular and parallel to path of travel.
The f100… it came to me with new outer tie rods and upon inspection the inners and pitman are in good condition. The ball joints also “appear” fine but I have not been able to load them properly for a good inspection. Radius arms and beam bushings are also not horrible looking.
The alignment feels great. The truck cruses down smooth flat roads at all speeds just as one would hope. Steering is responsive and tire wear looks fine. As soon as I hit the lumpy roads it’s all over the place. I’ve read comments that people experience this on highways and nice roads, seems to be part of anti I beam rhetoric… but handles fantastic off road?
Long winded, sorry. I have collected an all moog front end and will do the swap in a few weeks just because… but I am curious if it will make much difference. Could inherent changing camber with the uneven roads while maintaining traction(as opposed to loose off roading)be the issue?
Thanks for your time!
My truck already had poly radius bushings so I kept them but when with poly for the beam pivot bushings as I wanted a positive feeling steering truck.
As for the ruff ride I cant say as I never had the truck on the road before a total cab off frame rebuild but I dont think it gives a ruff ride, he11 it is a truck not a Cady!
It does not ride any different than my 02 Dodge Durango.
I also went with a Blue Top steering box for a tighter feel with the steering and love it.
The other "appears" is the alignment you cannot tell if it is good or not without putting it on the rack even if it goes down the "flat road" good. Caster or camber being off on an uneven road will make it wonder all over.
On my truck, I have kingpins and to change caster / camber you have to bend the beams. Mine was with in spec but it still wonders. I would like to add more caster but no one bends beams so I live with it.
In your case if you have ball joints that make bushing to change caster / camber but you need to "rack it" to know what ones to get and how they get installed.
If the shop is good and not just a spec card reader, they will know what needs to be done to get it better when driving like more caster as it make the car / truck go straight better and wheel return to center but can make it harder to turn the wheel from center but I dont think anyone would even feel that.
Now what I think beside the above is sway bars. I am guessing your 82 F100 is like my 81 F100 and did not come with sway bars.
They say if you can find them in the junk yards and swap them on or might find new online?
I believe they were standard on F150 4x4's or 87> 4x4 trucks, try and get front & rear bars from the same truck as they are matched set.
I dont have any sway bars but if I come across a set I would add them to the truck. I also pull a 20' enclosed trailer and I dont think the bars would help all that much and why I have not looked for any that hard.
Good luck and let us know how you make out with this as it can help others.
Dave ----
ps what size & shape tires you running? Have you tried to rotate them to see if that changes anything?
My post was really about maybe setting my expectations with the TIB suspension given my total lack of history with them.
On these messed up roads, I wouldn't say "rough" but rather self steering all over the place, different than bump steer. Most any vehicle does wander a little on these roads, but this boarders on alarming... and it does sort of shout ball joints(with my lacking knowledge of TIB) but I'd expect them to be flopping around visibility with a simple yank test based on what I feel on the road. Then factor in how well it drives and steers on smooth flat roads and turns.
I'll forge ahead with the updates, get a proper alignment and report back but it'll be a few weeks at best.
Not knowing how the ball joints are installed, it may not make a different now that I think of it, but jack up and get the tire off the ground.
Get a long bar and stick it under the tire and lift up and look at the joints, helps to have a helper
if see the knuckle move but not the beam the joint is bad and need to be replaced.Also dont over look the pivot bushings, you need to drop them down to see the rubber.
If you go poly, I would, You dont have to remove the outer metal shell as the poly bushings are made to fit inside them.
The fun part is how to get the rubber out of the shell? I drilled some holes in the rubber. I had bad old gas and I soaked the rubber bushings in it overnight and then set them on fire and burned the rubber out.
A little clean up with a wire brush, little spray paint, lube the poly bushings and put everything back in the truck.
If you go back with rubber you will need to remove that outer metal shell.
Maybe use a saw and cut thru the shell but not hurt the beam and then use a hammer & chisel to work it out ....... way more work than I wanted to do
Good luck
Dave ----
When I went from 86 K5 SUV, old box like ours, to a 02 Durango that has R&P I was lucky I did not get pulled over for DWI as I was all over the place.
I only get a little ov that when jumping between the 02 and the F100 as the F100 is little all over till I get use to it.
I just picked up a 07 Crown Vic with 21K miles and it has R&P steering and this thing is tight and it is like I am DWI all over again
Dont overlook the tires. I had a 76 E350 that had twin beam and going to Cali and back some of the roads it was all over the place and think the tires had a lot to do with it.
Dave ----
Dave ----
Tires, it came to me with some wide 16" American Racing aluminum wheels and big tires(245/70). I have them at 35psi. I'm looking to go back as stock as possible with a 15" steel wheels, 225/75 but was going to wait till I did the heavy lifting. Now I think I'll do that first just out of curiosity.
Also there is a imaginary line they draw through the top ball joint straight through the center of the lower ball joint, and this line is supposed to hit the center of the tire at road level. So when you turn the steering the tire pivots on center. When you run offset wheels, the tire pivot is moved outward beyond the factory designed centered pivot. The tire would actually roll a little bit as you are turning in this situation.
My 02 Durango is all factory with R&P steering but has 293K miles so a little loose from when it was new
My 07 Crown Vic is all factory, R&P steering and only had 21K miles and is tight.
It is fun jumping between all of them not only how they steer & handle but in braking also.
I would say after the parts swap, tire PSI checked and truck put on the rack, see how it handles. It may not be like the others you drive but thinking it will be better.
Dave ----
It's not till the front wheel drives really came out that they started to offset the wheels and then they did it to everything even pickup trucks that are rear wheel drive
Dave ----
