1992 e350 van opinions
How old are the tires? Take a long test drive. No frontend shimmy, smooth braking, no CEL, no RABS light, leaking gas filler hose,etc.
Lots of things to check. Some reading:
https://www.google.com/search?client...r+used+vehicle
How old are the tires? Take a long test drive. No frontend shimmy, smooth braking, no CEL, leaking gas filler hose,etc.
tires are new, radiator and thermostats new, along with master cylinder pads rotors and calipers
So the actual miles may be near 200,000 or even more.
How worn does the brake pedal pad look?
Is there documentation as to the miles? How many owners?
Buy a spare processor now
The van should last about forever
The transmission is the weak link, plan on replacing it someday, smell the fluid
I didn’t even think about the 5 digit odometer. I will get the vin number and have my buddy run the vin
It would be a gamble and if OP isn't a compentent DIY mechanic it would most likely be a money pit and source of frustration.
Just IMHO mind you.
Any 33yo vehicle will be a crapshoot. My '93 with 162k on it has served me well and the engine still runs fine but I've had to replace a fair number of things. I've done most of the work myself so it hasn't cost a ton to keep it going but if I had needed to pay shops, it would have been $1000's. The trans is starting to act up and it's about $4k to have it replaced so that's not going to happen.
My '95 E-150 5.8L E4OD has 140K original miles, and the original transmission. I've serviced several items due to age, but nothing unusual. While I miss the higher horsepower and torque increase of the 5.4L modular motors, I don't miss the idea of changing timing chains, guides and adjusters. The 5.8L is not going to get you there in a hurry, but if you are patient, and that van has indeed been well maintained and rust-free, I certainly would consider it. Watch for leaky rear side windows, (the big ones). Being a wagon, the seals may have let go. Sometimes you can seal them with flowable silicone, but the best fix is to remove, clean, re-seal and replace. Time consuming but not terrible. My body and frame are in great condition. When a tree crushed my roof and windshield, I jumped off the cliff and repaired it vs. searching for another van, so there's that. The '95 does benefit from the hydraulic roller lifter engine, where the '92 is traditional flat tappet. Tougher to get long life out of those, especially with today's aftermarket replacement cams/lifters.
The E4OD has a love/hate relationship with owners. Mine has been trouble free with good maintenance but I'm prepared to have it rebuilt and keep going when the time comes. There is the grand canyon of space between 1-2nd gear, and the one overdrive is a leap from D-OD. For a moto van, check to see what your factory gear ratio is, maybe 3.55?
From what I can see the body looks original and pretty straight, plus there's around $7-800 worth of tires on there already, so your purchase price is below $ 3K. Any vehicle in that price range risks motor or transmission rebuild. What kind of truck could you get for that price? Not much I would think. Worst case, you have a good body and frame, add the future cost of fresh motor or transmission rebuild and you are still below current market for any one-ton vehicle than can haul a bike and put a roof over your head on race weekend.
Pay a local ASE certified mechanic to do a pre purchase inspection (as wisely mentioned above), just so you know what you are getting into. Don't sweat the mileage, if the history and use is accurate, it's not hard to believe the mileage is either. I'd say age, suspension ball joints, seals, (especially rear main and transmission input) are suspect. 5.8L has a history of rear main drips and transmission input shaft seals due to age alone. Otherwise the ol 5.8L is quite reliable.
Means it "has 99 on the odometer" is all
Could have been changed, replaced or reset, no big deal if you like the truck
You should be looking at a few other things as well anyway
Like the pedals and for any wreck or body / frame damage
