Sponsored by: Auxito
mechanics say I got the wrong engine?!?!
Old Dec 11, 2003 | 06:49 AM
LxMan1's Avatar
LxMan1
It will say on the valvcover sticker if it is a Windsor built engine or if it was built in the Romeo plant. There are some differences in the internals of the two.
Jimmy
Old Dec 15, 2003 | 07:22 PM
HomerWinzlow's Avatar
HomerWinzlow
13670 POWER IMPROVED VS NON-POWER IMPROVED CYLINDER HEADS - TIP
WHEN SERVICING CYLINDER HEADS ON A 4.6L, 5.4L & 6.8L ENGINES, PLEASE BE AWARE THAT THERE ARE SEVERAL DIFFERENT COMPONENT COMBINATIONS. THERE ARE POWER IMPROVED (PI) AND NON-POWER IMPROVED (NPI) HEADS FOR THESE APPLICATIONS. THESE HEADS ARE NOT INTERCHANGEABLE AND LOOK DIFFERENT (INTAKE PORTS ARE SQUARE ON THE PI & OVAL ON NPI). PLEASE USE ENGINE TAG CODE, RF NUMBERS STAMPED ON HEADS (ABOVE EXHAUST MANIFOLD) AND VISUAL APPEARANCE TO DETERMINE IF PARTS ARE COMPATIBLE. FAILURE TO FOLLOW THESE CHECKS MAY RESULT IN ENGINE FAILURE. 1997-1998: ARE ALL NPI 1999 LIGHT DUTY TRUCKS, INCLUDING F-150, F-250, EXPEDITION/NAVIGATOR 2V: ARE ALL PI 1999 SUPER DUTY F-SERIES AND ECONOLINES: ARE NPI AND 2000 ARE ALL PI.
This is just an FYI for those wondering about the power difference in later engines.
Did you ever get this resolved on the problem posted?
darmahsd
Apr 25, 2026 03:22 AM
BigLoo
1983 - 2012 Ranger & B-Series
Apr 25, 2012 11:25 AM
Stephen67
106
Oct 31, 2011 12:37 PM
96f150
Mar 22, 2011 07:35 AM
Stephen67
38
Jul 12, 2010 12:04 AM
