1978 - 1996 Big Bronco
No start/keyless remote to blame
Old Dec 4, 2003 | 04:05 PM
Dutch123's Avatar
Dutch123
Have not used the keyless remote for 1 year -access is with key. Has been Solid red on the alarm eye. Today I flipped the valet switch alarm goes off 2 full cycles- close door, wait for chirp and set get a chirp- blinking red- remote does not operate door, etc- yes, fresh batteries - 2 remotes- neither. Open door same thing ql over again. Cannot get her to stop the blinking- can't disengae with valet- still blinking red. So, the rig does not start. What is that sequence for resetting. Forget about shorting the two terminals. I need to get her running to go to work . Uggh
Old Dec 4, 2003 | 04:45 PM
Dutch123's Avatar
Dutch123
I located a grey apadter with two pins and a grey adapter with a set of 3 and 2 pins. I did the wire short to the pins and got nada. this grey pin adapter was located inder the dash under the ashtray . I s this the correct connecter. I also read that it is located at the base of the sterring column?? I open th doors alarm goes off- and truck will obviuosly not start.
Old Dec 4, 2003 | 05:35 PM
Kemicalburns's Avatar
Kemicalburns
have you disconnected the battery and let it sit for a couple of min.?
Old Dec 4, 2003 | 06:34 PM
Dutch123's Avatar
Dutch123
disconnected the ???? what
Old Dec 5, 2003 | 07:22 AM
Dutch123's Avatar
Dutch123
The only grey adapters I have are located towards the center of hump under the ashtray, I cannot find the grey 2 pin connecter under the gas pedal or under the steering colum nor can I find the pigtail on the sterring wheel. Am I not looking in the correct place. Daily driver will not start because I cannot disengage the alarm .
Old Dec 5, 2003 | 10:11 AM
Kemicalburns
your little remote on your keychain has a battery, if its dieing that could be your problem. i believe they use a watch type battery.
late
Old Dec 5, 2003 | 10:44 AM
BillyBob69's Avatar
BillyBob69
What about dsconnecting the truck battery? Or does the alarm unit have its own memory battery?
Old Dec 5, 2003 | 11:08 AM
Dutch123's Avatar
Dutch123
Biiybob69 diconnecting the truck - you mean battery terminals?
Old Dec 5, 2003 | 11:12 AM
BillyBob69's Avatar
BillyBob69
Yep kill all power to the truck for a few minutes, then reconnect the battery. May reset the unit. (and unfortunately, the radio also)
Old Dec 5, 2003 | 11:15 AM
iskybantilus's Avatar
iskybantilus
yes, try to disconect the battery in the engine compartment, the large terminals .. disconect the ground cable, and let it sit for 15-20 mintues. this may clear the memory on the computer for the alarm, and allow it to start to function.
Old Dec 5, 2003 | 11:23 AM
Kemicalburns
goodness thats what i said way earlier, Dutch get yourself a manual and learn this stuff. you have been on this forum long enough you should know what we are talken about , hehehe
lol
Old Dec 5, 2003 | 11:57 AM
Dutch123's Avatar
Dutch123
Yah. I brain farted, got mad and threw the kitchen sink at her!!!
Of course I disconnected the and then the reset. So, alarm works as always now its those pesky fobs to reprogram. I'll use the 2003 manual entitled "How to Reprogram Your and Your" by Kemicalburns; HA!
tstang
Electrical Systems/Wiring
Aug 15, 2006 04:49 PM
moto
Escape & Escape Hybrid
Mar 27, 2006 02:07 AM
