Oil in coolant
Old Mar 14, 2025 | 07:07 PM
David Fehir's Avatar
David Fehir
Oil in coolant
My dad has a 2001 Excursion with the 7.3. Last summer he was getting oil in the coolant he took the truck to a local diesel shop and had it diagnosed. They said it needed a new oil cooler so my dad had them put a new oil cooler in the truck and thinking everything was fixed he had the cooling system flushed, had a new radiator installed and got fresh coolant. Fast forward to now and he still has oil in the coolant. What could be causing this to happen? Could this be a head gasket? Or could it be something else we're missing? Please Help.
Old Mar 14, 2025 | 07:21 PM
Pikachu's Avatar
Pikachu
Was it a Dorman cooler that was installed, by chance? They, along with many aftermarket suppliers, seem to have some quality issues.
Old Mar 14, 2025 | 07:29 PM
David Fehir
No the Mechanic got the cooler from the local Ford garage.
Old Mar 14, 2025 | 10:20 PM
JSPEX's Avatar
JSPEX
Just because the shop installed a quality part doesn't mean they did it properly. I'd be starting with double checking the cooler install, orings, etc and eliminate that possibility.
Old Mar 14, 2025 | 10:52 PM
David Fehir
I agree however I forgot to mention that the oil cooler was changed again by the same shop roughly 2 months later. So it was gone over a second time. Sorry I didn't mean to leave that detail out.
Old Mar 15, 2025 | 08:07 AM
Listor's Avatar
Listor
Cup failure??
Old Mar 15, 2025 | 08:20 AM
David Fehir
Originally Posted by Listor
Cup failure??
How do you diagnose cup failure? Im assuming you're talking about injector cups.
Old Mar 15, 2025 | 09:52 AM
Dan V's Avatar
Dan V
That's normally fuel in the coolant...more so, fuel floating on top of coolant in the expansion tank. You can normally see the line separating the fuel from the coolant...some dip a paper towel in the expansion tank....if it catches fire, it's fuel.
Old Mar 15, 2025 | 10:27 AM
David Fehir
Probably a dumb question but I'm assuming you'd do the paper towel test when the motor is at running temperature correct?
Old Mar 15, 2025 | 10:39 AM
z31freakify's Avatar
z31freakify
Can you ask your Pop's for a Pic of the resevoir it could just be residual oil from before.
Even when I fully flushed my cooling system using degreaser and dish soap I still mananaged to have some residual oil left, coolant is clean just have an oil line in my coolant bottle, and this was with rad off the truck with a clean fresh rebuild engine and flushed heater core.
Old Mar 15, 2025 | 11:13 AM
David Fehir
couldn't get a real good picture but I noticed when my dad stuck his finger in the tank there was oil floating on top of the coolant. This is what i got
Old Mar 15, 2025 | 03:29 PM
z31freakify
Eww thats a lot of mixing.
Maybe one of the end caps has severe pitting causing the problem? Maybe cavitation on the front timing cover (usually in the water pump area)
Old Mar 15, 2025 | 04:35 PM
Eman85's Avatar
Eman85
So they've change the complete oil cooler twice??? Or did they reseal the cooler twice?
Old Mar 15, 2025 | 04:40 PM
David Fehir
They changed the oil cooler twice
Old Mar 15, 2025 | 04:42 PM
David Fehir
I talked to my dad and he said there was pitting on the end caps that they found the second time they changed the oil cooler so the mechanic changed the end caps along with the oil cooler.
Shane Henson
Sep 1, 2025 10:06 AM
chad.parker123
Nov 22, 2021 09:53 PM
toolfan
16
Nov 7, 2019 10:37 AM
Heaveyhauler05525
Mar 24, 2014 09:07 PM
joshreed
13
Jul 18, 2009 03:26 PM
