Mirrors Stick
Old Mar 14, 2025 | 06:23 PM
Stumper2's Avatar
Stumper2
Mirrors Stick
Have a 2022 Lariat HD. Do the mirrors on these things need periodic lubrication? Mine tend to stick occasionally, generally not closing, but occasionally not opening . At first I thought it was cold temps but it does it in warm weather too. Both sides will do it randomly, no set patterns.
Old Mar 15, 2025 | 04:43 AM
Baja Fog's Avatar
Baja Fog
Mine started sticking too after I moved to the beach. IDK, maybe I'll try flushing it with a water jet, then spray in some white lithium or WD40?
OK, I did some research. The motor and gears that do the work are well buried inside the housing. Be prepared to spend four hours, more or less, to access them and lube them with a dry lube.
A after market replacement mirror can be had starting at $450 bucks or so: https://boostautoparts.com/products/...-2017?options=
Or shop EBAY and pay about $125- $500. Or Amazon at $250 ea. or less:
Amazon Amazon
Replacement motor and gear can be found for under $100.
Old Mar 15, 2025 | 11:13 AM
HorizontalHunter's Avatar
HorizontalHunter
I haven’t had a problem with mine but I hit the moving joints with a silicone spray a few times a year.
Bob
Old Mar 15, 2025 | 11:53 AM
Stumper2's Avatar
Stumper2
Bob
ive been thinking of doing that but there’s so much electronics inside I’m afraid of hosing down connections.
Old Mar 15, 2025 | 12:20 PM
HorizontalHunter
I just spray the moving joints with a squirt and then run them in and out a few times and fold them in and out a few times. I don’t soak them.
Bob
Old Mar 15, 2025 | 01:30 PM
kjfrazi's Avatar
kjfrazi
Trailering
2021 F350 and I do the same a few times a year. Also, hit the running board joints too. No problems at all.
SuperOriginalGuy
Oct 1, 2021 10:19 AM
michael a
1947 and Older Ford Trucks
Aug 19, 2015 07:10 PM
dannyd2450
Dec 22, 2011 08:11 PM
Matt M, PA
Sep 12, 2009 07:54 PM
