Engine perches
Old Mar 14, 2025 | 03:25 PM
Joey_14's Avatar
Joey_14
Engine perches
For my '79 project F250, I need engine perches that set on the frame for a 300 / straight six. I see a local guy parting out a 4x4 manual (same as mine) F150. Are they interchangeable?
Old Mar 14, 2025 | 07:30 PM
nluttrell's Avatar
nluttrell
The 4x4 and 2wd perches are different. 4x4 doesn't have the same crossmember as 2wd.
Old Mar 14, 2025 | 07:53 PM
benbuilder's Avatar
benbuilder
I have a set
Old Mar 15, 2025 | 04:35 AM
Joey_14's Avatar
Joey_14
Both trucks are 4x4 manual. Donor is F150 mine is F250. Should be the same, right?
Old Mar 15, 2025 | 04:57 AM
benbuilder's Avatar
benbuilder
mine are from a 2 wd truck. I know 4wd is different, so not sure how to answer the question sorry
Old Mar 18, 2025 | 04:31 PM
Joey_14's Avatar
Joey_14
After much searching this remains one of the most misunderstood aspects of dentside tech. Some people say they were able to re-use their v8 perches after moving them forward. Others insist the 300 must have their own set. Very confusing.
Old Mar 18, 2025 | 09:09 PM
mterickson's Avatar
mterickson
77.5 and later F250 had a wider frame than the Highboys, and as I recall they were widened to the same width as the F150 at that time.
If you can measure the width of your frame and that of the donor truck, that should tell you if they will work. As long as the frame width is the same in the engine bay I think you'll be okay. Also take a front to rear measurement off a reference point that is the same, such as radiator support. The mounts for the 300 might be located slightly forward or back compared to where they're bolt to the frame for V8's. As far as I know the holes will already be in the frame to support all positions for the various engine options.
Since the 300 is much narrower than the V8 I am assuming they are different frame perches, but don't know for certain. The difference in width my be accounted for on the engine mount side of things. The mounts for the V8 is only a couple inches thick. If there are brackets of some sort on the 300 making the engine mount longer/taller, you might just have to move the perches forward or back.
Sorry I can't be more help
Old Mar 19, 2025 | 11:31 AM
Pickupmanx2's Avatar
Pickupmanx2
I have a set in my shop, I'll check and see if there are any part #'s on them, I bought for $120 when I was going to put a 300 in my 77 F250 4x/low boy, ended up just rebuilding the 351Measly as I needed to get it done when I was buying my house.
The holes in the frame are there, they are towards the front of the truck, IIRC I had to remove shock mount bolts and use them for the perches.
On the 2wd trucks, yes, you can move the perches forward and use them, I have done it, also the same on the slicks, 61-66 2wd, I haven't done a bump yet to say for certain, but... I'm going to suppose so since both before and after the bumps work.
PM me, they're yours for what I paid for them +shipping if you want them.
Old Mar 20, 2025 | 07:30 AM
Joey_14's Avatar
Joey_14
Appreciate the offer, I'm not going to spend any money until I know I need them. I'll keep working on it, gonna be a long process. Thanks.
Old Apr 29, 2025 | 07:20 AM
Joey_14's Avatar
Joey_14
After messaging and trading pics with PickupmanX2, I ended up buying his perches. They are NOT the same as the ones that were used for a V8 on a F250 4x4. I could NOT have just moved mine forward on the frame. I received his yesterday, and they are uniquely contoured to attach to the forward mounting point on the 4x4 frame in a way that my original ones are not. Plus they are taller and more forward-angled. They are altogether different and needed MANY THANKS to PickupmanX2. I'm off to find how to leave him positive feedback in the trading forum here.
Old Apr 29, 2025 | 09:12 AM
Pickupmanx2
@Joey_14 Awesome to hear!! Glad they worked for ya!!
DirtyLarry79
Dec 4, 2023 10:24 AM
Tarek75
Jul 8, 2021 09:50 PM
havi
13
Feb 26, 2011 07:54 AM
Qwill
May 26, 2009 12:48 AM
