when i pulled the 400 out of my 79 bronco for rebuilding i failed to mark the motor mounts for left and right. and they fit ether way. so how do i decide which is left or right. thanks mudder trucker.
Mudder,
If they fit either way, what's the problem?
Seriously, go to the autoparts store and ask to see a motor mount. compare and your good to go.
KingFisher
Is one motor mount larger than the other? I've got a 460 and my drivers side motor mount is about 2" longer than the passengers side, so the motor sits a little off center, toward the passenger's side. This gives the motor enough room to clear the steering box. I think the 79 Bronco is the same set up. Don't know if this helps or not.
